Page 10 of 38 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... LastLast
Results 91 to 100 of 375
Thread: Drift Tyres
  1. #91
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    kuhmo ku36 fronts very good but are no re55 or re540
    kuhmo ecsta spt rear very grippy on my road car but not enough on the track car but time will tell.. the only good thing was i used only 6 of them in a day
    might be tryen some r1r on the rear next praccy day
    oh and slippery tyres for low power use sava intensa, darkhorse 50, falken ze329 and the old ze326, badyear eagle f1, badyear eagle ventura?? hmm i will try more later
    maxxis maZ1 are very grippy for fronts but tear apart in chunks on the rear and mav1 are not too good for anything
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  2. #92
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    THE BEST CHOICE!!! i've never had anything bake as hard as savas, made my 60kw sprinter look like it had 260rwkw. wish you could still buy these babies new
    NEAR MISS
  3. #93
    Veteran bigm's Avatar
    Gold Coast
    savas do smoke like crazy,
    have them on the daily lol, but yes shitty steer tyres
  4. #94
    Veteran Robo86's Avatar
    Rob
    how do savas go in the grip/wear department on the back
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  5. #95
    Senior Member shawn_26's Avatar
    Shawn
    Southside
    I have Advan Neova's for steer tyres. But keen for something slippery as fark for my 15x8rears. Can someone reccomend me something readily available that is super slippery in say a 185/50/15 or near?
  6. #96
    Senior Member Simon-KE70's Avatar
    Simon
    well after the DSC comp just gone i can now say that i love RE001's in both the dry and the wet... they are simply awesome value for the money for a steer tyre.
    i also ran Toyo proxes 4's on the back in both conditions and in the dry i found them way too grippy for my set up and power (190 rwkw and 6/4.5 kg springs) with 28 psi cold in them to start with... next prac session i upped them to 40 psi cold and they were awesome.. just the right amount of grip and slip.
    didnt delam and they lasted a while too... was pretty happy with that over all.
  7. #97
    Ken
    Spearwood
    Yeah your problem would have been 28psi to start with, waaay to low.
  8. #98
    Simon
    not really... after speaking with other guys who run them but in 17's and with lots more HP, they are the best at 30psi HOT temps and then kepty at that for the best grip and best long life. so starting at 28psi cold isnt low at all.
    they are the sort of tyre that works best at a lower temp... just my car doesnt have the power to carry long slides with a real grippy set up.
    also in the wet i was running them at 24psi and they gripped up REAL well... was able to do 4th gear scando's into the tyrewall and bring it back and nail it lap after lap... with higher press's it just wouldnt do it
  9. #99
    Mark
    Southern
    my most recent drift attemps a was running half worn re540s potenza semi slicks
    but they started to delam shortly after i clicked 4th gear at the end of the baskerville drift section
    i am now thinking i need more grip
  10. #100
    Ken
    Spearwood
    Wet is obviously a different case altogether.
    RE-001's in comparison to higher performance tyres are nothing special, so to get grip from them I guess some of those guys would run the low 30's. RE-01R's, Neovas, R1R's need to be much higher, 40+ cold.
  1. 15 by 6 Superlights and drift tyres
    By Hen is a total nutcase in forum Car Parts For Sale
    Last Post: 10th May 2008, 09:57 AM
