Page 17 of 38 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... LastLast
Results 161 to 170 of 375
Thread: Drift Tyres
  1. #161
    Bayden
    south australia
    Nurioopta
    but wont the 15 be harder to spin ? eg wider wheel more tread more grip ?
    i was thinking 13 cause id run a 165 onthe 5.5" rim so straight edge maybe lil stretch wid say 40 psi cause i dnt really want grip i want it to be able to slide and spin lol.
    and i also noticed me 15 ar 6.5" im runiing 195 atmo with straight edge for front shouldd i go to a 185/50/15 ?
  2. #162
    Aaron
    In the Mountains
    if its a good tyre with a stiff side wall they should be fine on a 15x6.5 rim..
    you get more flex at the back due to the nature of how your using the tyre.
    trust me a 165 on a 5.5" rim is not going to be stretched. 175 on a 7" rim isnt what i would call stretched either, its more a tight/undersized..
    185/50R15 is prob a bit of an expensive size. just got the 195
  3. #163
    Bayden
    south australia
    Nurioopta
    ok ill just got the 15" alround as long as i can afoord it other wise ill have run something i can get from tyre piles
  4. #164
    Senior Member s14seriesII's Avatar
    Mark
    Southern
    run 46 psi in the back and about 32 to 38 in the front depending on tyre used should slide fine.. just make sure the back suspension is hard or on the bump stops..
    Owner built and tuned 9000rpm 402kw atw 3sGTE - AE86
    Quote Originally Posted by Beau View Post
    4ages are for the scared
  5. #165
    Bayden
    south australia
    Nurioopta
    yea rear is pretty stiff trying to work on that at the moment
  6. #166
    Bayden
    south australia
    Nurioopta
    Also would i be better of running 17s on the front ??
  7. #167
    Veteran Konakid's Avatar
    Henry
    Eastern
    hell no.
  8. #168
    Bayden
    south australia
    Nurioopta
    ok fer enought lol y there wide id get alot more grip wouldnt i there 17x8s
  9. #169
    Veteran driftke70's Avatar
    Ryan
    Buderim
    cause people would laugh at you behind your back
    only time you should ever go bigger past 15 is to clear brakes. otherwise you have more unsprung mass, more expensive tyres, gayer looking rolerskate, fitment is so wack, center of gravity is way high etc.
    wheelfriends.wordpress.com
  10. #170
    Bayden
    south australia
    Nurioopta
    ok all gd just wondering but all gd doesnt matter ay !
  1. 15 by 6 Superlights and drift tyres
    By Hen is a total nutcase in forum Car Parts For Sale
    Last Post: 10th May 2008, 09:57 AM
