Basically if you see a price in my top post, I have bought it.
16331-16020 outlet, water (The bit that bolts to the side of the head that the rad hose goes on)
Hi all
Sparkle86 the part that your are after is available out of Sydney warehouse I can send straight down to you overnight.
$130.00 plus freight
Thanks jess
0421820394
does any one have part no for jap t 50 slave cylinder
mine caqme with out one.
31470-12050 clutch slave cyl. 4A-GE
The TE72 one also works just as well, and easier to get. You could get a new one from ABS or Repco too. I suspect the genuine AE86 one is aluminium.
can u get a genuine gasket set,piston and rings pretty much a rebuild kit for a 4agze ae101
I guess you probably could. Tell them you have a Levin GTZ:
E-AE101-ACMXR
4A-GZE
AE101-5018171
Do you have the same info for a silvertop 20v (ie chasis no. etc) that i could use.. i got a few gaskets i wanna grab from toyota but the parts guys get cranky n they oD me some times
Thanks tin can you have pm
Here you go, one of many vehicles with the "silver top" 20 valve 4A-GE. The parts man should be able to order everything off this:
Corolla Levin GT Apex
E-AE101-ACMZF
4A-GE
AE101-5118694
So 6 weeks later they finally arrived. Guy was very helpful today. This time he tells me they usually move people on because "we don't get trained in this stuff". But because I made an effort, knowing in advance the actual part numbers I wanted and having a Jap GTV build plate he was happy to help. He still checked them all though. Two of the caps arrived within a week, the other two took much longer. Funnily enough, a reasonable used set came up on ebay whilst I was waiting to hear if new ones where available, so got them too for $25! Just in case.
If interested, the centre caps for the option 14 x 6 Intra wheels are part no. 42603-12340 $23.19 each
The 5 tooth speedo drive gear is 33481-12030 $60.85
Hopefully that will pay for itself by not getting a speeding ticket. Just need to find the 19 tooth plastic gear now. (looks hopefully Jonny's way)
