Hi mate,
RDA272 in slotted would be $240 for the pair.
Regards,
Greg
hey mate
can you get a me price on a pair of slotted Peugot 604 Discs the rda equivalent of DBA272
thanks
Hi mate,
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Hey mate can you please pm me your best price on standard replacement rotors to suit a 1996 B5 audi A4 FWD 1.8 non turbo 20v. Front and rear set...
BENT MECHANIX - Garage 20:
Hi mate,
Unfortunately with these you've got a few options... Need to know if your front rotors are solid or vented, and whether your rear rotors are a hat type rotor, or a hub type rotor. The more common option is solid front rotors ($89 each) and hub rears ($59 each).
Regards,
Greg
Yeah cool just went had a look to confirm, fronts are solid floating disc (this is what you mean by hat correct?) and rears are solid hub type (by this you mean it houses the wheel bearings etc correct?)
Don't require fronts just yet but defiantly need rears pretty soon, so just shopping round for the most competitive pricing.
How much is postage on a pair of rears to 4127 Brisbane?
Yep, that's correct, sounds like you've got the more common option. Courier would be $8.
Regards,
Greg
cool I'll let you know if I decide to purchase (in the next 2-3 weeks hopefully)
Cheers Greg.
Niz
oh also how much for the cheapest pads to suit? Cheers
The absolute cheapest set of pads would be RDA, at $29 for the set. The cheapest quality set of pads would be something like QFM HPX for $79 for the set.
no probs, I should be making an order in the coming weeks, you have the best prices Ive found so far, will let you know.
