Get the front up on stands then get under it while it's running. That should hopefully sort out where it's leaking from.
Otherwise most mechanics should have a tool that clips onto the top of the radiator and lets you pump it up to pressure. Doing that should also show you where the leak is (essentially same effect as the first suggestion, but you can get higher pressures and you don't need the engine running).
