Results 1 to 4 of 4
Thread: can you run an oil cooler between your remote oil filter
    Member KuRt's Avatar
    Kurt
    Gold Coast
    i have an oil cooler and a remoter oil filter which is going on my sprinter and i was wondering can you run an oil cooler between your remote oil filter housing and the housing that srews onto the block im pretty sure you can but i want some reasurance cheers
    Adam
    New South Wales
    Yep you can.
    It goes..
    Out of engine>to remote mounted filter>through the filter>out of filter in oil cooler>out of cooler>back into return engine.
    Just make sure your cooler can cope with full oil pressure and full flow.
    With a setup like that ALL the oil that is going to your engine goes through the cooler first and is at full pressure.
    On the other hand AE82 coolers are a bypass system where some oil gets cooled then dribbled back into the sump. These only flow a little bit and so may be restrictive if used for full flow.
    What brand of oil filter sandwhich plates are people using and what size port do they have. I'm looking for a sandwhich plate that mounts to the block with -10 fittings.
  1. Replies: 22
    Last Post: 13th August 2012, 07:13 AM
  2. Where to find 3SGE BEAMS Oil Cooler & Oil Filter Relocation Kit
    By 4A-G3 in forum Technical - Questions
    Last Post: 3rd February 2011, 12:12 AM
  3. complete oil cooler and oil filter remote locator kit
    By slide86 in forum Car Parts For Sale
    Last Post: 23rd September 2007, 08:43 PM
