Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Disc brake conversion bits for T, S series drum brake diffs.
    I have two sets of disc brake conversion parts for drum braked diffs. This definitely fits T series diffs. Reports indicate that they will also fit S, E, F (live axle) diffs too.
    Single piston, 280mm solid disc. Awesome internal drum handbrake. Alloy backing plate.
    Included is:
    - Calipers with pads and flexi brake hose section with all fittings
    - Backing plate with handbrake assembly and handbrake cables
    - Good thickness discs.
    Price is $200 for the calipers and backing plates. We'll throw in the discs free if you want them.
    Photos below show the parts included.
    $200 pickup in Melbourne (North eastish) or add postage to your door (around $20 registered without discs, $40 if you want the discs too as this takes the package over 20kg)
    Dusty
    Lynbrook
    is this corona stuff??
    Yes.
    Aaron
    In the Mountains
    and it bolts straight up to aus spec t-series diffs... with the kit you are providing..?
    dose it change the brake balance..?
    All bolts up to the diff.
    To get the whole setup running you need to:
    - Fit a 5mm spacer ring (slice of pipe) outboard of the wheel bearing or get the Corona bearing retainer plates.
    - Move shock mounts 10mm inboard
    - Shorten handbrake cable. Or use a SV11 handbrake cable front section.
    Yes, it gives you rear bias if fitted with no other changes. Opening the factory brake bias block and removing the spring will solve this problem.
    riojin
    what kind of bias will be given after you have removed this spring? will it work the rear brakes at all then? please elaborate
    Elite rthy's Avatar
    Leo
    Tulla
    if it's anything to go by I am using the same disks with calipers that appear very simular and I have done the brake bias controller modification and it pulls up great with good rear bias, just about perfect infact
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    will I have to modify anything to fit this on jdm t series??? (kouki)?? if not ill but a set on wednesday
    MY JZX83 (clicky)
    Brendan
    NORTHSIDE YO
    and why do you have to move shock mounts over?? too much offset on rotor?
    MY JZX83 (clicky)
    You need to move mounts because the shock can foul on the caliper body. It's only a matter of a few mm.
    These should fit a Kouki diff if it was originally DRUM brake. Disc diffs have a different bolt spacing around the diff flange and so wont fit. You can check to see if the bearing retainer plate is the same on your diff and T18/RA40/RA60 to be sure.
    As Q-boy has said, removing the spring from the factory splitter block just changes the biasing. Bias is generally much better for 4 wheel discs after this.
  1. Rear drum to disc brake conversion!
    By Mikeylimiter in forum Technical - Questions
    Last Post: 10th July 2012, 12:23 AM
  2. Wtb t series disc brake conversion
    By armc89 in forum Cars or Parts Wanted
    Last Post: 20th November 2011, 10:40 AM
  3. From Drum to Disc brake
    By Kamikaze in forum Technical - Questions
    Last Post: 6th September 2007, 01:27 AM
  4. Disc brake rear end vs Drum brake
    By Lappy in forum Technical - Questions
    Last Post: 21st January 2006, 05:35 PM
