-Topic Reopened-
Another one locked out of nowhere. :rant:
These are orginally from a 20v silvertop so they will suit any 4age with a later model crank (42mm big end and 20mm small)
- these have had the edges carefully ground, not linished which takes heaps of material away
- crack tested and linished in a aerospace approved buisness not in a backyard mechnics workshop
- comes with 4 brand new small end bearings still in packets from Toyota as the original small end bearings copped a few stray shots.
- new un-fitted arp rod bolts
these would handle 9000 revs no problem
I am in S.E suberbs of vic but will post anywhere
will provide pics shortly
$300 ONO
-Topic Reopened-
thanks
oh also I am open to swaps with or without a cash difference, I am looking for the following:
7afe or 4afe head after 1993
16v 4agze pistons and pins
heres the pics:
and during the perperation process:
price drop to 260
i have a set of ae92 small port pistons and pins here. might be interested in a swap with cash your way as the pistions are used but in good order.
will most likley speak too you on msn next time i see you online.
see if we can work out something.
sounds good I will be online tonight
pm sent dude
sam will the arp rod bolts fit bigport..?
if so im intrested in those if you will seporate them.
