There is so much on this it is ridiculus look up hilux brake upgrade, you will need corona struts
hi
does any one know of an aftermarket caliper or off any other car that bolts straight on to the standard sprinter braket for the caliper or something simular. cause i need the front to have more braking power. don't care about price atm just seeing what me options are
and i know about the rx7 caliper adn mini cooper disc upgrade but want something more simplier if its possible
thanks,
there is that t3 big brake kit thing i believe it involves will wood calipers and some massive disks.
there is a guy on this forum with them its costly as but a good upgrade
<div class='quotetop'>QUOTE (deleta @ Nov 12 2007, 08:57 PM) </div>$1100 (or very close to it) delivered to you, ready to bolt up with everything needed. Try as you might but there's alot of stuffing around getting things to work with other upgrades, and you'll be hard pressed to do it completely for under $1100, so why not spend the money and do it right?
Contact Justin (Bustin_86) at Kyouteki for all you T3 needs :2thumbs:
Hi mate,
As previously said (thanks guyswe sell a Wilwood big brake upgrade which sounds like it will fit with your needs. They go for $1060 which includes shipping to your door.
There is one drawback, due to the lack of dust seals on the calipers they are unable to be ADR approved. This just means that the brakes cannot be a legal upgrade to your vehicle which may conflict with engineering requirements if you have any, most people dont. Having said that Wilwood are a well respected and trusted brand and i am very confident in their product.
If im able to help you any further please let me know!
Justin.
Kyouteki Team.
Hoppers Stoppers also do a kit for about the same price using a falcon caliper on a 280-300 disk (not sure on the specifics). Also not sure if they will send the kit for self install, but it might be worth asking them.
