well how about ANY induction tips n tricks then? put a smallport in and have no intake on the mannifold
hey all,
has anyone fabricated an induction box, or similar to enclose and direct flow, most probably to a pod filter on a RWD GE?
Something similar to this: "http://www.vividracing.com/catalog/product_info.php/cPath/4460_5317/products_id/5707"
similar to this, but not as an actual unit, more a hot air shield/flow directional box to a pod filter?
I know its a bit of jibber-jabber, but hope ya catch on to what i mean
If you put 'cold air intake' into the search function, you will get some ideas.
i used to have an ARC airbox.
cool piece of kit.
togue205 now has it. i think at some stage he wanted to make copies of it?
Yeah I have one too. It is very nice, and has a bellmouth inside. Welding is a work of art. Problem is making sure you have the AE86 specific box, not the MR2 one, plus getting the right air filter. The box is a unusual filter size and ARC sourced filters are expensive. I ended up finding a SAAB K & N filter for it which I then located VERY cheap of US ebay. Less than a third of the cost of one here.
[attachment=18958:IM000483.JPG]
rx8 cold air feed, fibre filled heat foil, a few cable ties light and efficient, doesnt look great tho, but it works
<div class='quotetop'>QUOTE (gunbz-r @ Nov 20 2007, 01:25 PM) </div>Rx8 feed - ths an aftermarket or factory ietm? sounds alright but i just cant visualise it all together
factory one, bell mouth n all, i worked on one that'd been burnt so i ripped it and said it was damaged, spuin i let it go with the levin, but ive found usually the most basic systems work
Quads for the win you tools. tHEN YOU DON'T NEED ONE. Ha ha
ohh quads make cold air sweet lol u tool, they still do well with a cold air feed
