should be only very slightly less or the same as power stearing lock.
Most mods you will do to get more lock have to do with the lca, make sure the lock stops are gone. Also tubulars let you make decent use of any of the shorter knuckles going around.
lock spacers i believe will work, howvere i have found i hit the lca befor running out of lock.
If your keen you can come round and look at mine, though its on blocks we can chuck some wheels on and have a play.
