haha what ideas would they be?
Specs of the above
15 x 10 - 12 GTR superlites
205/50/15 re001 adrenalines
St 141 strut - shortened 65mm
KYB AGX 4 way adj short stroke shocks
otomoto coilover kit - 8kg/mm + helper springs
R32 gtst calipers
Ford falcooon rotors - machined down to 280mm and re drilled to 4 x 114.3
T3 Camber plates
T3 upper hat system
T3 33mm mx73 RCA's
T3 ae - mx conversion knuckles
T3 Outer tie rod kit
T3 Castor rods
Selbys 24mm adj swaybar
soon to be made
Adj LCA - T3 weld on LCA kit
Looking sweet man!
sweet fitment, might have issues with scrubbing on lock?
full T3 front suspension looks tight!
thanks man - shoudnt have issues - i guess we'll see soon hay.. if so nothing the good ol persuader wont fix! aka hammer
How are you planning on covering those wheels.???
Bigm's KE looked pretty sick with CBY flares on it....
Isn't Pidwell runnin 10's on the rear of his under stock metal.??
I ran the CYB flares for an 86, would recommended it for the x7 tho, because if u want to go low enough you loose your rear doors (because the arch is a slightly different shape) and it looks wack.. cool from a distance tho
datsun 240z or 260z flares are the way to go if thats what u want? but im pretty sure u want all metal do get that hammer out
yeah pidwell is running 10's on the rear under flaired metal guards... i only just saw that the other day on some youtube vid - i wish i could find it again!. got me even more pumped..
as for the fronts.. the guard wasnt in position properly.. im going to flare it as much as i can and then some more.. and if they still dont fit im going to pull the guard out where it attaches near the bottom of the door to get that little bit extra... ive also slotted the mounting points for the 1/4 panel so i'll get a few more mm their.
i dont want bolt on flairs at all... it can be done!! haha
if this rain stops ill have some more progress today... but it seems to always rain on my days off...grrr
oh it will be on the street... but for how long is the question...
