Page 2 of 30 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 11 to 20 of 296
Thread: Project Ksev
  1. #11
    Gone
    Joel
    Picton
    to change a tyre? hmm i didnt exactly plan on having a limb under the car to teach my self a lesson.
    anyway... UPPPDAAAAAATE.
    got my engine crain out of storage today.. 1st time used.. picked it up hell cheap and got a free 500kg engine stand to go with
    engine is out, exhaust out, all main break and fuel lines out, fuel tank out
    will be onto the heater box and pedal box tomorrow.
    pics
  2. #12
    Senior Member OMG866's Avatar
    Nick
    Miranda
    looks good mate. love to see 100rwk
  3. #13
    Site Supporter Javal's Avatar
    Josho
    Swastika fan!
    Neo-nazi 4k.
  4. #14
    Gone
    Joel
    Picton
    i was hoping the chain would snap so i could fall over laughing while the 4K hit the floor!
    yeah 100kw is a bit optomistic but we can always dream hehe thanks guys
  5. #15
    E-Famous (Remeber your roots)
    Looking good. Not a fan of the wide body though.
    I hope you have more plans then that for the suspension also.
    marvis.
  6. #16
    Gone
    Joel
    Picton
    im not really going for a clean look at all.. kinda want it to be tough
    i didnt really list much in the beginning..
    suspension.. front
    coilovers, TRD 8kg springs, shocks.. not decided, cusco camber plates
    Ae86 LCA's for now.. mayb rona or sigma later
    40mm RCA's, Selby 24mm adj sway bar.
    need to sort out castor rods.
    urethane bushes
    ae86 JDM rotors n calipers
    Custom rack + AJPS lock spacer = scub out on inner guard with 14 x 7.5 and 185/60 and ae86 LCA's
    PS arms added later.
    Rear.
    TRD 6 kg springs TRD Blue adj shocks. Selbys 20mm adj sway bar.
    AJPS adj panhard. stock trailing arms for now
    T18 ae86 Disc break rear TRD 1.5 way LSD (wish it was 2way, just going to shim it up)
    Urethane bushes
    i think thats about it.. for now
  7. #17
    ae86 LCA's are the same as KE70 LCA's. Best off going coronas.
    Sounds good.
    marvis.
  8. #18
    Gone
    Joel
    Picton
    ive been stuck into it for the last 2 days and now its break time for halvies so it thought id post up the progress.. pics ill post later.
    ive installed and Ae86 pedal box into the 70 which had some mods and some support welded into it. y buy a 71 or T18 for 200-250 when the 86 one works fine and the pedals sit perfect!!..pics will show what i did, and also have used the ae86 steering colum support, which is a brace that runs the whole length between the pillars, that had to be shortened and welded in, will give some extra regidity as well. along with that also the Ae86 steering column, the Ke70 indicator + wiper switch has the same mount as the Ae86 indicator so off came one and on with the other, so it has an 86 adjustable column with the 70 indicator/wiper mech. also had to change the mount that goes thru the firewall to the ae86 item.. holes needed to be drilled out to allow for some give.
    The engines are out of both cars and the 4age is sitting pretty next to the car ready to go in, All the sound deadener has been removed.. Thank the lord for Dry Ice!!!
    JDM fuel tank and moddified filler neck also in.
    pics up tonight
  9. #19
    Gone
    Joel
    Picton
    JDM fuel tank + filler install:
    I used the filler grommet from tha 86.. moddified, and all i had to do was cut a section from the solid 86 filler pipe and add in the flexable rubber section from the Ke70 tank.. perfect!
    Aerospace approved aluminum tape! awsome!!
    AE86 pedal box(s)
    Added washers to spread the pressure load on firewall
    This bolt was cut off to get the pedals as close as possible.
    Adding this piece of steel make the assembly so much more ridgid!!!
    I was going to make a bracket but i thought this isnt going to come out and it was withing welding distance, just needed to do some hammering to get it sitting right.
    With the steering column installed it sat 20mm off to the left.. NOT HAPPY!
    THant was soon to be fixed!
    i had to cut a 20mm section out of the brace bar on the RHS of the mount and then cut and add 20mm on the LHS of the brace bar
    You can see the sections cut out above.
    yeah i know i stuffed up.. i wasnt happy with the hight of the column(to low) but i had already welded on that bracket..so i had to cut off the end of the brace and flip it over so i could raise the whole brace bar to a good height.ahh well it will still work fine.
    Break master and clutch master installed.
  10. #20
    Veteran corknose's Avatar
    Callum
    i hope u were kinda joking about your wide body thing caause if not ur gunna have a massive gap at the boonet , parker and bever pannel?
  1. 3RZ Ksev
    By lappy in forum KE70 / AE71 Owners Forums
    Last Post: 26th May 2014, 06:37 AM
  2. LAZYs KSEV
    By Delazy in forum KE70 / AE71 Owners Forums
    Last Post: 17th February 2012, 01:39 AM
  3. ksev part out
    By Sturgey in forum Car Parts For Sale
    Last Post: 9th March 2009, 11:42 AM
  4. SR20 into Ksev
    By barnzy - ksev in forum Technical - Questions
    Last Post: 17th January 2009, 10:31 AM
  5. kSEV or AE71
    By KE70briskev in forum Cars or Parts Wanted
    Last Post: 11th September 2007, 04:53 PM
