You can use the front half of a RA40 tailshaft.
Is it true that these are a perfect fit for a t series diff and a w series gbox in an ae86?
Save me a lot of time if true
then custom from there?
I know a TA22 tailshaft is a 1 piece, and fits T series diff and T50/K40 gearbox. I use one of these in my TE37 thing but cut it 50mm shorter.
A RA23 and RA28 and RA40 and RA60 use a 2 piece tailshaft like in a AE86. They all use a T series diff. They also use a W series gearbox. So yes... a RA23 or RA40 tailshaft should work. But I don't know about the length.
<div class='quotetop'>QUOTE (Skin @ Jan 6 2008, 04:34 PM) </div>No just AE86/T18 rear half to suit the T series diff. Thats what I have in mine.
Awesome
Cheers man
Saves heaps on a custom tailshaft
Ok so i did this. It did work however the mounting points which are on the front half (ra40 half) of the tailshaft are about 1.5 inches out. Had to weld brackets on to make it work.
Anyhow
how far should it push into the back of the gearbox?
Ian Weatherhead told me when measuring up for my tailshaft to put the yoke all the way in, then pull it back out 20-25mm, with the suspension down, to allow for when the diff travels up the yoke (as said above) if too close to the gearbox it will smash the box, and you dont want to do that to he Wigg Motorsport box now skin head haha
