pm sent about the oil cooler
Hi guys.
I've got some stuff to clear out, it's sitting here not being used so they need to go to a good home....and so I can get some new tyres.
Location of items: Upper Mt Gravatt (South of Brisbane, QLD), unless otherwise specified.
Contact info: PM me on here.
__________________________________________________
Zenki T-series Open centre diff with 4.1 CW+P gears
Item Description:I was told this came from a TA22 Celica. Use it for the cw+p gears or what ever. I have no use for it.
SOLD
Item Condition: Used, good condition
Price: $60 pick up only (could sort postage but it'll probs be mega exxy)
No pics, it's in storage but I'm sure you all know what a diff centre looks like.
Factory 4AFE AE92 Oil cooler core with sandwich plate, clamps and fittings
Item Description: Bolts up to your 4AGE. Cheap alternative to running an aftermarket kit. All you need is some oil cooler hose, source a 4AFE sump or tap a hole / make a hole and weld a nut into your sump for the oil return. Comes with everything you see in the photo. As seen in Jonny Rochester's AE86 build thread! >>
Item Condition: Used, but still good.
Price: SOLD
Smallport 4AGE Reduction Starter Motor
Item Description:This magical contraption spins very fast and turns your flywheel; which in turn, helps to start your 4AGE engine. Can be used with 200mm flywheel (big-port) or 212mm flywheel (small-port). Not sure if it'll work with 4AGZE flywheels (220mm?). It's a lot smaller and lighter than other 4A starters. No chunks missing from the starter gear thingo either. Did I mention it sounds wicked when it turns over?
Item Condition: Used, unknown internal mechanical condition.
SOLD
Price: $30 + postage
Old school Toyota gear knob
Item Description: Screw it onto your shifter and change gears with it.
Price: $5 posted
Stickers
Update: 21/04/09 - I found a few more stuck in some uni text books lol. More added.
Item Description: Vinyl stickers, both printed and die-cut varieties. Limited amount available. If you buy more than 1, I can send them all in one envelope.
Item Condition: Brand new
Price: $5.50 each postage
x 3
x 3
Price: $4.50 each posted
SOLD OUT
Price: $3.50 each posted
x 1
15 x 6 P00 Offset Meshies of some sort.
Item Description: Selling these for a good mate of mine, He's hoarded too many 15's as skidders for his S13 so he needs to liquidate some. They come with poverty spec tyres on them.
Item Location: Mansfield (South Brisbane, QLD)
SOLD
JDM AE92 Smallport 4AGE ECU
Item Description: This came out of a JDM AE92 Corolla Levin GT-Apex, apparently the JDM ecu's have a slightly higher rev limiter than the ADM ecus. It worked 100% fine before it was taken out. All of the pins are straight and unbent.
Price:$100 + postage
Thank you for looking!
1984 ae71 Panelvan - Sold
2000 Lexus IS200 - Cruiser
ECU added.
I'll take your centre. Sent you a PM.
i will take the gangsta stickers thanks! cash waiting
I'll take the starter.. sending pm now...
BENT MECHANIX - Garage 20:
Updated Top post. I'll send reply pm's soon too guys.
Pm'd!
Pm sent
