Results 1 to 5 of 5
Thread: setting valve timing on 4a SOHC - help needed
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    hey guys,
    I am just after some help in setting my valve timing on my 4a SOHC, after replacing my headgasket.
    It's idleing at 1600rpm and used, wait for it, QUARTER OF A TANK of fuel and i only drove it 25km!!!!!
    It runs smoothly tho, no missing/spluttering... I am guessing the Valve timing is advanced.......
    I dont have a 4a manual, and i dont know what marks/positions that i need to set. I have never done this before, so make it simple for me....
    Much appriciated,
    J Riftin
    Veteran slide86's Avatar
    Huw
    Hills
    you sure you dont have a fuel leak?
    if it was using that much fuel i would be chugging black smoke and probably wouldn't even run
    but, the 0 mark on the crank should be on the marker and there should be a mark on the cam pulley that should line up with the backing plate. ive not done a 4ac head, but most engines are like this, 4age's are
    JoJo
    ACT
    Tuggeranong
    no fuel leak, no smoke, but exhaust smells very fumey.....
    when you took the carby off you didn't shake it around or turn it upside down or anything like that. didn't mistreat it. accelerator pump could be jammed open. maybe get another carby or overhaul yours.
    JoJo
    ACT
    Tuggeranong
    It's ok, i fixed it.
    Fine now...
    Slide86 was spot on with his instructions...
    Thanks slide86.....
  1. Setting timing without marks on crank pulley
    By geoff in forum Technical - Questions
    Last Post: 15th February 2012, 12:14 AM
  2. 20 valve timing cover spacer (middle timing cover, alloy plate)
    By KE70Man in forum Cars or Parts Wanted
    Last Post: 26th August 2011, 06:30 PM
  3. Setting the timing and cas
    By slideways in forum Technical - Questions
    Last Post: 17th March 2009, 11:30 PM
  4. 4A SOHC Headgasket
    By Maxhag in forum Cars or Parts Wanted
    Last Post: 3rd January 2008, 04:44 PM
  5. 4AGZE/GTE Timing setting
    By AE71 Rolla in forum Technical - Questions
    Last Post: 29th September 2007, 07:49 PM
