Results 1 to 10 of 56
Thread: Master cylinder question for AE86
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Default Master cylinder question for AE86
    Hey guys,
    I have to get myself a bigger bore master cyl for my brake upgrade.
    The kit suggests a 1" master.
    So my question is, Does anyone know of any larger Master cylinders that will bolt up to the AE86 booster?
    I believe the Mitsubishi Starion Turbo one is a 1" and bolts up, but I have been looking for months, and are too hard to find. Brand new, and thru the Starion club, they are $415, and they said there was only one left in the country.
    I have also heard something about an R32 or R33 (cant remember which one) one bolting up, but its not confirmed.
    Does anyone know of any other Masters cyl's that might work for me?
    thanks,
    JoJo
    Site Supporter Javal's Avatar
    Josho
    R32 Non-ABS master cyl fits.
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    Hey man, srroy for not SMS'ing ya back, got busy with crap
    "Tokico Brake Master Cylinder" is what i've got
    it's a 17/16th MC with the same bolt pattern as the AE86/KE70
    $270new
    Pic
    Reeece
    Casula
    i bought a r32 with abs MC from nisswreck for $100 bolts straight in and needs orignal lines to be modified to suit
    Josho
    See if you can find a partnumber for that. Not that it's toyota, but it will be something.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    i think a mitsu pajero one bolts up
    Josho
    Correct.
    Justin
    DC
    Downtown
    USA
    I'll try and find one, but from memory, it didn't have one in it.
    JoJo
    ACT
    Tuggeranong
    What size bore is then Mitsu Paj one?
    And What size is the Nissan R32?
    Tom
    SOR
    Mitsubishi Pajero one is 15/16 bolt straight on Aus 86 booster. But one of the outlet use a different fitting. What brake setup are you running that require a 1"?
  1. Brake Master cylinder question
    By luke20 in forum Technical - Questions
    Last Post: 29th October 2012, 10:58 AM
  2. brake master cylinder question?
    By shinny in forum Technical - Questions
    Last Post: 13th October 2007, 02:15 PM
  3. Noob question, starion master cylinder
    By slydar in forum Technical - Questions
    Last Post: 18th June 2006, 09:04 AM
