any closer pics of finished gaurd?
The primer was wet-sanded with 320-grit (fairly rough!!), then painted with the 'touch up paints' available at supercheap. Supercheap spraycans are 100 better than autobarn and repco paints, just remember that .. no i dont know why .. i just have more luck with them
No clear coat, just four or five coats of paint. Spray on a light coat first, then layer it on, without getting runs.
man.. that shit might rust ey
might do a write up when i do the widebody rear on the panno...
really good write up look dope now
time for fronts
thanks for the write up!
very very useful.
indeed
thats exactly what i did. cept more hammering and less angle grinding. still i recomend the cut/glass/bog stlye but atlest mack sure you use rust converter on the shit befor covering it. we got 10mm over what was normally a guard flaring jobbie. could go wider but i dont have stupidly wide rims ahahaha
what size wheels we talking?
I fit 9 inch -15 under stock guards
