Results 1 to 10 of 12
Thread: diff oil
    hey guys just wondering what a kouki trueno jdm obviously, would use for diff oil ? not sure if it needs different oil for different lsd's ? im guessing its just a standard one that came as an option
    Veteran Robo86's Avatar
    Rob
    i have kouki levin, drum t series with trd 2way, i run penrite 85-140 (if i remember correctly) seems to be great, its used for heavy duty gear, diff got quieter when i put it in, and it doesnt clunk
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    wouldn't it specificly need limited slip diff oil?
    Senior Member amulday's Avatar
    Amulday
    Central
    The Penrite Limsip? 85-140 stuff is suitable for LSD's. I use it also, heaps quieter.
    Penrite 10/10ths has been replaced by the Penrite SIN range I was told just the other week.
    amulday.sam
    HR ARMY
    RED BEAR
    Jonathan
    Any diff oil that is for High Pressure and suitable for LSD is fine. It will say this on the container.
    The normal default would be Valvoline LS90.
    Veteran biggo's Avatar
    Nick
    Noosa
    normal locker would be penrite 90 - 140
    yair the hoeny shit
    Poh
    Bevo
    roughly how much oil is used for the t series diff??
    and dumb question (new to diff area)
    is there a an fill and drain plug type (like gearboxes) when changing oil?
    Ok
    Seamus
    Milton
    i used castrol(?) VMX80/90 in both my gearbox and diff.
    was good for the gearbox (much quieter than what WAS in it), but for the diff it sucked.
    i'll be using the blue shit robo86 used in his, its the bomb diggity
    ^ Clicky clicky!
    Veteran ae71neo's Avatar
    Travis
    Blue Mountains
    <div class='quotetop'>QUOTE (poh_86 @ Jan 24 2008, 11:53 AM) </div>Fill diff until it spills out of the fill hole.
    Yes there are 2 holes.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    I use Extra Heavy duty (4x4) LSD diff oil
    Go with a well known brand
  1. Another diff oil thread...
    By --Redwork-- in forum Technical - Questions
    Last Post: 28th January 2010, 07:15 AM
  2. Diff Oil
    By orido in forum Technical - Questions
    Last Post: 21st October 2007, 12:45 PM
  3. Which diff oil do you use?
    By EMD-KE70 in forum Technical - Questions
    Last Post: 8th April 2007, 11:22 AM
  4. How do you.. filling oil shocks with diff oil
    By enigma in forum Technical - Questions
    Last Post: 10th January 2006, 05:11 AM
  5. diff oil
    By Whip in forum Technical - Questions
    Last Post: 23rd November 2005, 08:43 PM
