Results 1 to 10 of 10
Thread: weights
    Jul 2005
    hey,
    1. does anyone know the weight of a gen 3 3sgte with manifold and clutch and accessories?
    2. nsw standard sprinter drivers, what car weight does you rego paper say?
    thanks.
    Jul 2005
    yeah awesome 28 views and none fron nsw, yeah right.
    Apr 2010
    <div class='quotetop'>QUOTE (newby86 @ Jan 26 2008, 02:26 PM) </div>my old sprinter was nsw rego at 940kgs
    Jul 2005
    great man thanks very much.
    Jul 2005
    anyone got 3sgte weights or a second or third for ae86 weight.
    Engine/Trans____________Weight_______Comments
    4AGE 20 Valve & T-50........155kg............Complete as fitted to car (less exhaust manifold)
    T-50 5 speed.......................29kg............RWD Gearbox as fitted to some Corollas, Coronas etc
    3SGE two litre......................92kg...........Head and block complete only - no manifolds, alternator, starter etc
    3SGE & T-50.......................132kg...........Includes Twin 45 DCOE Webers, intake manifold, alternator, starter motor, bellhousing and T-50 gearbox - cast iron block
    3SGE & T-50.......................161kg...........Complete assembly on carburettors as fitted to car
    *Above is NA 3SGE not sure which generation -if you want to compare 3S-GTE then also add weight of turbo, exhaust manifold, intercooler plumbing etc
    Table found here You may also like to refer to and also has some useful info.
    Not sure what the rego paper states as weight of ADM Sprinter (~930kg) - I just posted
    Harry
    VICTORIA
    when i weighed my standard 86 when it was complete it was 941kg
    i believe the 3s with turbo + everything associated to run it incl intercooler etc was 20 to 25 kg heavier than a full standard 4age with air con
    keep in mind that standard cast ( non turbo) exhaust manifolds weigh quite a lot
    the w58 is something like 10 kg heavier and depends what u do for a diff
    Elite rthy's Avatar
    Leo
    Tulla
    when I weighed my T50 it was 30.5kg
    and my spare 20V engine without any brackets, accesories or flywheel: 88kg
    Feb 2008
    anyone know the weight of a bigport flywheel and is a bigport flywheel the same as a small port one,cheers
  1. wheel weights fulling off...
    By iwantarolla in forum Technical - Rims & Tyres
    Last Post: 28th February 2012, 09:32 AM
  2. Wheel weights on BRAND NEW rims? Not normal?
    By maxhag in forum Technical - Rims & Tyres
    Last Post: 9th June 2011, 03:59 PM
