Can you use both FD and FC calipers on this bracket?
Hey All,
What I have here for sale is some custom CNC'ed adaptor brackets to suit a massive 294mm Rotor. These have been machined for our needs and don't know of anyone else offering an adaptor to suit 86 struts and an RX7 calliper with such a large disc. The disc retains very similar offset to that of standard, and only requires new holes drilled to suit the 86 hub. I run 15x8 negative 4 offset on my AE71 and these clear my wheels. I have the part number of the required discs, you can get these in DBA series 4000 which I run on my set up.
If the interest were there I can organise for another run of these to be done, minimum of 5 sets though.
I currently have 2 sets of these on offer for $300 plus postage, located in Tasmania. Also if I were to do a re-run I couldn't be 100% sure of the price although would be similar.
Any questions please ask.
Jake
Can see Photo's of the set up in Klusio's Build Thread:
I got nothing.
Yes mate, you can.
I got nothing.
will 14inch wheels still fit?
i doubt it. 15's minimum.
how does the disc mount with these adapteers in place??? i have a dodgy old setup on my car and the disc is only held in position by the calipers when the wheel is off the car.
kiss ass like a bitch, so you can get ritch... but your boss gets ritcher of you!!!!
I haven't tried with 14's, but my 15's are close so I very much doubt it, in fact, I'd say no.
I got nothing.
The adaptor picks up the original calliper mount holes on the strut and the disc mounts to the hub as per it does originally.
Cheap big brake upgrade!!
I got nothing.
Dba 42524 294 x 22?
Thickness is correct, 22mm.
I got nothing.
