Results 11 to 20 of 23
Thread: 3s-gte engines
  1. #11
    E-Famous (Remeber your roots)
    They will be beams but?
  2. #12
    Elite rthy's Avatar
    Leo
    Tulla
    did they fix the oil pressure problems in the gen3 when converting to rwd?
  3. #13
    Veteran driftke70's Avatar
    Ryan
    Buderim
    probably good to note too that the gen 3 comes from the factory with forged internals and ballanced crank. Good for 500 od hp on standard internals "from what ive heard"
    also something to note is the angle they sit on in fwd form, they tilt back in celicas a fair way,
    here is some info too.
    3S-GTE usage in Toyotas
    Generation Year Model
    1 1986-1989 Celica ST165
    2 1990-1994 Celica ST185(-1993), MR2 SW20 (MR2 Turbo)
    3 1994-1999 Celica ST205, MR2 SW20(1995+)
    4 1997-2003, 2003-2007 Caldina ST215 (GT-T), ST246 (GT-Four)
    gen 1 - 182 hp @ 6000 249Nm @ 3200
    gen 2 - 221 hp @ 6000 270 Nm @ 3200
    gen 3 - 251 hp @ 6000 305nm @ 4000
    wheelfriends.wordpress.com
  4. #14
    Ryan
    Buderim
    they never really had problems, people just made dodge sumps
  5. #15
    I always thought the Gen 2 and 3 were a fair bit better then the Gen 1 for internal componite strength. The Gen 2 also has the small port head which can be a plus if the head is ported were it makes horsepower without loosing airspeed through the Bigport.
  6. #16
    Anthony
    the beams sump/windage/pickup system is spot on. QR 5th gear proven The only real difference between gen 3 and beams is an extra oil drain at the rear of the head. Ive putting a gen 3.5 (ST215 motor) in an 86 upright atm, and I have a beams next to it to copy off so I plan to replicate the oil drain addition. Will get pics along the way and do a tech article.
  7. #17
    Ryan
    Buderim
    you rekon i should?
  8. #18
    Veteran slydar's Avatar
    Dimitri
    gen 1 and 2 have the same intake ports, i have a gen2 intake on my gen1.
    gen 1 and 2 gte are internally similar, its at gen 3 where it all changes (just about everything)
    gen 3 is where the ports change. also have shim under bucket.
    gen 1 na is the weakest by far, smaller crank, different crank pcd even. smallest oil pump, ect ect. but i am still confident it can hold together with some boost if i keep the rev cut down, i will probably set it at just over 6500rpm. i am only aiming for 140-160 rwkw. i dont really understand why anyone would want more, maybe i have been driving na 4age ae6s for too long, but that is double the power i would usually have (or close to it).
    the oil control problem is a function of sump design. toymodders kill them sometimes when rwd, but then IP guys do not.. IP guys run them NA at BIG rpms..
    medwins seems to be going fine and its only a gen2.
    78's
  9. #19
    Anthony
    ill get some pics and you can decide. im still 50/50
  10. #20
    Thomas
    West Brisbane
    the 3sgte im getting is out of a 90 model gt4, so is that a gen2 i think checked on autospeed , all the fab work i can do myself i just dont no a hell of alot about converting it to rear ie which gearbox, flywheel, bellhousing, inlet manifold all that shit to use
  1. RWD 3S-GTE (Gen III) Package
    By 3sgteRA28 in forum Car Parts For Sale
    Last Post: 1st December 2010, 10:25 AM
  2. Replies: 13
    Last Post: 11th November 2010, 05:22 PM
  3. 3S Planned Sa63
    By Jono.C in forum Other Toyotas
    Last Post: 12th September 2010, 03:02 PM
  4. 3S-GTE water lines
    By tin can in forum Technical - Questions
    Last Post: 29th January 2010, 10:55 AM
  5. 3S-GTE conversion
    By FUTO_GT in forum Technical - Questions
    Last Post: 24th April 2009, 10:56 PM
