13 x 7 -1 Enkei AP Racing Full Set
Going to be fitted to a KE11![]()
its funny, peoples opinion about tyre size.
if you ever see a C110 skyline with stock guards and really good fitment... there running 14x8 -14's with 175/60's its the majic/offset/width/tyre size...
each to there own i guess...
i guess 86's are different as there not really zokusha but none the less... if you want fitment you need to give/take alittle![]()
fail comment of 2010 so far...
i just laugh when someone finds out i slide my car
and the first thing they say is "omg so do you run stocko cheescuters on the rear when you go to the track!!?"
my fave comment is "are thoes flipped/reversed" no there jsut 10" wide rims... not special enough to get 7j's and the reverse them![]()
of the vanilla coke or wheels?
I'll take some more once we have the bolts in and the whole lot polished.
Rim probably sits about 1" past guard so should sit nice with 205's.
His rim pile is beoming quite impressive
sarcasm is a verbal tone.
how the fuck does 'lol' signify a verbal tone!
Good stretch also depends on the tyre itself, the 175/60 on that C110 skyline is a directional Potenza (note sidewall) and the Works Excels are like 14×8-14 The one above on a 9 is a fair strecth, but fitted a pretty pedestrian tyre with a really bloated sidewall.
that is also true, rev spec is a very good pic ive been told.. problem is we only get pedestrian tyres untill you get into the bigger dia's
hence... import tyres when you get rims (prob not ideal for 86 drivers but will be good for me)
sussed these out on Yahoo Japan:
theyre sexalicious
Hazzard
Thanks,
Andrew.
