<div class='quotetop'>QUOTE (A.Short @ Mar 30 2008, 12:00 PM) </div>Hey mate welcome to the forums
the 4AGE 16v rwd is the easiest swap. The trans will bolt up fine although the clutch master will be very near the exhaust (probably use extractors and heat wrap them)
Yes you can use the 4AC mounts
You can use the stock rear end no problems
Don't see why you can't use a MegaSquirt ecu
Don't know about in the USof A but here in aus the mechanical parts are not too bad but panels are getting expensive
