Where is the pause exactly?
my check engine light is coming on while iam driving but it dose not come on until about 2400k rpm i have short the diagnostic box it has a sequence with it flashing 2-4-3-5 with a pause in between i have searched on the net for the codes but unable to find anything if anyone could help it would be great
thanks
its actually 4-3 pause for bout 2 secs then 5-2 then 4.5 secs it starts over again
this is sorta similar to mine drops out at about 2000rpm and comes back on at 3000
i might go to toyota tomorrow and see if they can diagnose it with there computer iam not too sure on how to read the codes properly
You've read the codes fine. Code 43, no STA signal. Have you push started your car ever? This code can flag if you do. 52 is knock sensor and is far more serious, and is also probably the cause of your poor response. likely causes are faulty knock sensor and faulty ECU in that order. Is it a smallport or a ZE?
its a bigport gze afm motor and no i don't think i have ever push started it
