Results 1 to 10 of 12
Thread: 20v Head 16v bottom end.
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    20v head 16v bottom end.
    Hey guys i no this is a real noob question.
    But has it been done and is it worth doing?
    How much more power gain is there and is a big job with lots of hassles?
    Do you guys have any pics or is their any faq articles on it?
    If anyone has done it please tell me if its worth doing?
    Elite rthy's Avatar
    Leo
    Tulla
    <div class='quotetop'>QUOTE (damo46 @ Apr 15 2008, 02:00 AM) </div>can be done but it normally isnt, this is because of the low cost of 20V's usually mean its cheaper to just swap the whole engine. The notable exception to this is if putting a 20V head onto a 4agze block for turbo applications. Even then people usually just put the 4agze pistons straight into the 20V engines, which fit straight in. For an actualy power increase with the 20V head thats a pretty long debate and unfortunetly theres no clear winner in that one.
    Veteran slydar's Avatar
    Dimitri
    depends which 16v you have. if you have a dig around the faq and also tech reference, you wouldn't need to ask this question.
    basically, your question is too brief and so really what youre asking actually doesnt make sense.
    78's
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    <div class='quotetop'>QUOTE (slydar @ Apr 15 2008, 11:16 AM) </div>which 16v do u need to be able to do this?
    Veteran biggo's Avatar
    Nick
    Noosa
    hehehe
    thats funny, a 16v is a 16v
    but FYI smallport/20mm gudgeons
    Senior Member 4door's Avatar
    Apr 2010
    South Australia
    Hills
    putting 20v head on 16v block.. i assume still the firewall issue.
    Nathan
    Gold Coast
    <div class='quotetop'>QUOTE (trueno_kim @ Apr 15 2008, 01:18 PM) </div>yes cause of the dizzp so running coil packs would be needed
    Jun 2009
    Damian
    ive got a bigport 16v..
    so is it worth doin?
    Dave
    <div class='quotetop'>QUOTE (damo46 @ Apr 15 2008, 07:25 PM) </div>i just had a thought, if you use 20V head, you would need to use 20V pistons (with the 5 cutouts), and they have the 20mm gudgeon size, so youd need 20V conrods, which have the 42mm (think its 42, the larger of the 2 sizes) conrod bearings, so then youd need a smallport/20V crank. and therefore a small port/20V block to fit said crank in?
    so your current bottom end couldnt be used anyway? (since you said you got big port, so 40mm and 18mm bearings/gudgeons)
    unless the 42mm bearing sized crank fits in a bigport block.....
    prolly just sell your 16V, save a few dollars, and buy a complete 20V then stick it in without opening it up
    if you were doing it the other way around (16V head on 20V bottom end) then it prolly be worth it, if you had the individual parts sitting around (Stronger bottom end etc).
    - Blaise Pascal
    Elite rthy's Avatar
    Leo
    Tulla
    what makes you think its a stronger bottom end dave? unless your using a blacktop as an example
  1. mach oil temp gauge plus st 20v bottom end with 16v head
    By dehney in forum Technical - Questions
    Last Post: 7th March 2011, 09:42 PM
  2. Replies: 4
    Last Post: 4th January 2011, 07:34 PM
  3. 20v head on 16v bottom
    By hillclimb86 in forum Technical - Questions
    Last Post: 22nd September 2006, 07:38 PM
