Results 1 to 7 of 7
Thread: Removing front windscreen
    Senior Member Marco's Avatar
    Marcus
    Jindalee
    As title states has anybody ever removed a front windscreen on an 86 without breaking it how did you do it?
    cheers in advance,
    marco.
    Mar 2008
    haha i "tried" to remove my ke70's windscreen in one piece about 20 minutes ago............cut away at the glue/seal shit for ages then did the old sit in between the front seats and push with my feet thing.....shattered almost instantly!
    still got it out though
    Senior Member gumbie's Avatar
    Jordan
    Sunshine Coast
    Yes. Remove all the trim around the screen on the outside and inside and run a knife under the screen to cut the seal and push out. Just make sure that you have cut all the seal away or the above will happen.!!!!!!
    john
    nsw
    liverpool
    where you located (nsw) , i have a mate who does windscreens for a living ... has doena few sprinters, including mine .
    Senior Member Paw-DK's Avatar
    Mar 2010
    Paw
    Denmark
    General Area
    Christensen
    <div class='quotetop'>QUOTE (Jonny Rochester @ Apr 15 2008, 10:54 PM) </div>from johhnyR
    Senior Member Moebius's Avatar
    Christian
    From what I've heard, even the pros tend to break them every now and then.
    Mar 2010
    Paw
    Denmark
    General Area
    Christensen
    all depends on the condition of the screen, size of stone chips if any and how much urethane was done previously
    but usually using piano wire will get the job done without cracking the kient
    and the shaft knife is normally used when the window are already cracked soo its a nice and easy job
    urethane is 10times stronger then normal general purpose silicone but on a hot day its slides easy peasey haha
  1. removing front rotors
    By subaer in forum Technical - Questions
    Last Post: 17th June 2009, 11:52 AM
  2. Removing front springs
    By doridori in forum Technical - Questions
    Last Post: 8th March 2009, 01:27 PM
  3. removing front guards
    By driftster in forum Technical - Questions
    Last Post: 28th September 2006, 08:42 PM
  4. Sprinter front windscreen
    By defect in forum General Topics (No Technical Questions)
    Last Post: 16th June 2006, 02:42 AM
  5. removing front bumper
    By ke25 racer in forum General Topics (No Technical Questions)
    Last Post: 30th May 2006, 06:45 PM
