nice looking ride dude that looks tough
Hi guys,
This is my AE86, I bought it from a mate with alot of the work done
then did alot more, thanks Tom
Blacktop 20v
TRD 0.8mm Headgasket, 3.9kg Xtreme Flywheel, T3 Trumpets.
Haltech E8, LS1 coils
4-2-1 extractors, 2 1/4 exhaust with resinator and 1 muffler and moto cannon
JDM Drum Brake Rear End With 2Way Os Giken centre and lowered swaybar and 4 link brackets
4.3 CWAP
JDM Front Brakes, Mu Secret shoes
VL turbo fuel pump external pump, new lines
JDM t50
TRD Leads
Alloy Air Box With Flat Pannel Filter
Nulothane trailing arm bushes
JDM pedals, Bride Brix drivers seat, Razo gearnob, Nardi classic wheel
Top Stage Front Lip
Jap brake booster
Jap dash cluster
C's short shifter
RDA Slotted/Vented Rotors
Custom lower control arms 30mm longer each side
Custom roll centers 50mm
Koni adjustable front shocks short stroke ( FRONT COIL OVERS)
Koni adjustable rear shocks short stroke
Koni coil over kit (Top Hat Etc)
Custom Spring Heights Front And Rear
Cusco camber tops
Nolothane caster rod bushes Replaced
Lower ball joints Replaced
Whiteline traction brackets
Whiteline Front Strut Brace
15x8 Unknown Jap wheels, -5 rear and +12 front offset
24mm whiteline adjustable front and rear sway bars
Caster rod bracket spaced down to remove anti-dive
White line pan hard rod adjustable
Sparco Bonnet Pins/Clips
Top stage Front Lip
5 Point Roll Cage SAFETY 21
Stripped Rear Seat & Carpet, Painted Grey Hammer Tone. Comes With Seats Ect
TRD rear duck tail
JDM lights blinkers and foglights
Whiteline tailights
hand flared guards
Yeah thats about it, I'll get some action shots up soon.[attachment=266721010532.JPG]
About time you got this up!
You got more specs on it? Should chuck them up.
Looks great!
look ssooooooo much like chapls old car!
sweet car man, looks clean as, what are the wheels, have never seen them before
you havent seen them on 86 becuase theyve been redrilled from 114 pcd I'm pretty sure thats whatben said when i spoke to him. how much do you want for your 16v dude? PM me some more info about it and what gearbox youll be using behind your 20v. thanks!
It made 72rwkw on Pulse Racings dyno last week, Looking at about a $1000 for the engine, ecu and loom
yeah chicks
i like it alot mate!
very tasteful
Some new Pics.
