This is for you guys who get a loom from a wrecker and someone has decided to cut some of the plugs off....
this is the wire combo's to run a 3sge tps loom side plug on a 4age loom
3SGE
BR = E2 (i suspect EARTHed ECU
W = VTA
P = IDL
P-L = VC (common with pin 4 on the AFM)
4age
Y = VCC
R = VTA
L = IDL (L = blue wire)
BR = e2
ill get javal to add the 3sge throttle body bit in...
