courtesy of ke70dave
what is need in a fuel system for a 4agte. fuel pump, fuel reg, lifter pump, surge tank anything else? and how would i go abouts making a box for it so its CAMs approved. can people just post some diagram or pics of your fuel setup so i can get some ideas. but i think a box or exclosure is a must
thanks for looking and reading, hope you can help me out
in the pics these a efi fuel pump and fuel pump. whats the difference, is one a lifter pump
yes fuel pump is a lift pump (low pressure), efi is the main pump (high pressure)
I'm doing the same thing in mine as I need a surge for the 4agte. Atm I have a Bosch 040 for the EFI pump from the surge to the fuel rail. I'm thinking of having a 2L surge tank but I'm not sure what low pressure high volume fuel pump to have from the tank to the surge tank. Ive been told a carby fuel pump like a holley blue or something could work but I'm still not sure.
What also would be the best way for a registered car to have the surge tank?
And is there an advantage of maybe doing a surge tank in the fuel tank.....?
This is the next thing on the list to do to get the car going.
Any help would be great.
use the VL lift pump.
thanks gullie for that,
i still need more pics of different fuel setups
what you mean you want pics??
google image search man :2thumbs:
egsample
- Blaise Pascal
