Results 1 to 5 of 5
Thread: ke70 build from ae86
    Rob
    Hey,
    Sadly killed my 4age 86' got a ke70, and looking to move everything...incl 4age
    Just hope to confirm a few things:
    1. ae86 pedal box can be used ? everywhere ive read says ae71, can i get away with my ae86 pedal setup ?
    2. fuel tank - is the fuel pickup flange the same, i have an intank efi pump on the 86', will i be able to bolt it into the ke70 tank?
    3. ke70 / ae86 strut tops, same bolt pattern ?
    4. ae86 steering rack/coloumn bolt across easy or do i need to mod the coloumn up to fit ?
    tried to search some of this stuff but was struggling for these last points. any help would be great.
    damo
    Veteran verm69's Avatar
    Dave
    Gold Coast
    1. The Ae71 and AE86 cross members are same, not sure about the pedal box, but you'll need alot of things from either a AE86 or AE71 to get a 4AGE into a KE70... good luck
    the rest i can't say for sure...
    -=Back by popular demand=-
    Rob
    5. will my ae86 exhaust bolt up ?
    forgot this one...
    Strut tops yes.
    Pedal box, my mate is about to use one but unsure if it will work yet...
    Jase
    South Australia
    Glenelg
    pretty sure ae86 pedal boxes needed to be modified to fit, same with an ae86 t50 xmember in a ke70.
    everything else should be mint.
    ae86 strut tops will fit but may decrease caster.
    also I'm pretty sure you could just use your ae86 fuel tank in the ke70. or just fit the lifter pump to the ke70 pickup.
  1. My KE70 build
    By Anthony13 in forum KE70 / AE71 Owners Forums
    Last Post: 7th May 2013, 07:59 PM
  2. Ke70 Build
    By Low Style in forum KE70 / AE71 Owners Forums
    Last Post: 23rd July 2012, 10:38 PM
  3. KE70 build up.
    By miniman1 in forum KE70 / AE71 Owners Forums
    Last Post: 20th May 2010, 05:03 PM
  4. KE70 Build
    By nelpd96 in forum KE70 / AE71 Owners Forums
    Last Post: 28th February 2007, 03:56 PM
  5. KE70 Daily build up
    By -Leigh- in forum KE70 / AE71 Owners Forums
    Last Post: 10th September 2006, 10:57 PM
