holy shit, what car is that a truck?
for a car of this weight the recommended pressure would be about 30psi
i run 28psi in the front, same sized tyres and wheels as you and about the same in the rear.
for spirited driving i sometimes drop the front pressure to 25psi same with the rear.
for drifting i up the rear pressure to about 30psi
remember all pressure is cold as warm tyres increase the pressure.
id say that is way too much pressure and you will probaly find as your tyres wear that the middle will wear much faster and it wont be even. perhaps for max tyre life and minimum fuel consumption with mostly highway driving then maybe 35psi which would be good for towing as well.
try dropping the pressures to something like i run and try the brakes. the lower pressure provided a larger contact patch with the road. with lower pressure you will get a bit more tyre roll but with a sports orientated tyre with a stronger sidewall than the $65 maxi grip tyres that you find on the rubbish tip they should have stronger sidewalls to start with.
