Well seeing as these things are cheap as now, ill put up how to wire them in. According to old mate Rex Kelway you can also use these for MAP/TPS but they are designed for datmo's with AFM's.
Red - 12v
Blue - Ground
Black - input to ecu
White - output to thingy (from AFC to AFM/MAP/TPS)
Bigport GZE with AFM the ecu input signal is VS. Farked if i know what MAP sensor is, but read up an you will get the idea.
