Results 1 to 10 of 17
Thread: are spacers that dangerous?
    i was thinking of putting spacers on the rears for the mean time i sorta want 6.5s to fill the rears
    Oldschool Member
    Mar 2008
    not dangerous if you arent silly with them
    Andrew
    properly made bolt on concentric spares arnt
    gunbz-r
    what kind of spacer?
    Andrew
    <div class='quotetop'>QUOTE (Sam_Q @ Jun 18 2008, 09:48 PM) </div>
    Agreed. Best is if they are hub centric and wheel centric. And use studs that go all the way through.
    Elite rthy's Avatar
    Leo
    Tulla
    yeah come to think of it going for longer studs would be even safer, shameless self plug time:
    Russ
    Congupna
    anyone who says spacers are dangerous havent used them.
    of course slip on ones or AJPS bolt ons are, but decent quality ones are perfectly fine.
    Veteran v-tec's Avatar
    Grant
    Gold Coast
    Be wary of slip on spacers if you plan to use them cause they obviously shorten the amount of thread that the nuts can use.
    Bolt on spacers are good as long as you get the ones with the correct alloy and studs
    Sep 2006
    i heard that if you put spacers on 0 off-set rims, you will loose a bit of power due to the increase length it travells through? is this true?
    are negetive off-set rims better than 0 off-set rims?
    what if i use 25mm spacers on +25 off-set rims? is it the same as no spacers on 0 off-set rims?
    Elite rthy's Avatar
    Leo
    Tulla
    total crap, however wider tyres and heavier rims are meant to make more friction and hence more power loss.
    same, many people do this so that the wheel clears a multi-piston caliper.
  1. Toyota UK Add banned for Promoting dangerous driving
    Last Post: 24th November 2012, 04:17 PM
  2. how dangerous are bolt-on spacers?
    By ae86 in forum Technical - Questions
    Last Post: 7th January 2009, 10:18 PM
