Results 1 to 4 of 4
Thread: ae92 E51 gearbox swap into aw11 mr2
    Mar 2008
    hi all i have an E51 gearbox from a levin ae92 lying around in my garage i am currently using a c52 with my 4agze which is making 150hp atw's the c52box is starting to not handle the power, so i am looking at instaling the E51.
    i would like to know if this could easly be done i have a clutch,flywheel pretty much everything is there to bolt up to the motor.
    but have herd things such as the selctor shafts are placed backwards, and that you need s/c transaxles.
    has anyone done this?
    or no anything about the swap all info is muchly appreciated
    spaniel
    Jonathan
    The E50 series gearbox uses bigger axles, so you will need them also.
    Oldschool Member
    Sep 2008
    selector shaft is on the wrong side from memory, but it can be swapped.
    i remember seeing something about it on twincam.org, if that helps.
    Oldschool Member
    Sep 2008
    here is the site... this explains it all...
  1. Replies: 1
    Last Post: 23rd November 2012, 06:49 PM
  2. aw11 mr2.
    By timmay in forum Cars for Sale (Toyota Only)
    Last Post: 14th April 2009, 09:45 PM
  3. aw11, ae92, ae101 bits and peices WITH PHOTOS, mainly aw11 things.
    By spanielmr2 in forum Car Parts For Sale
    Last Post: 1st January 2009, 08:59 PM
  4. bigport tvis 4age RWD, e51 gearbox clutch&flywheel
    By spaniel in forum Car Parts For Sale
    Last Post: 8th September 2008, 09:21 AM
  5. aw11 mr2
    By redsprinter in forum General Topics (No Technical Questions)
    Last Post: 27th November 2006, 01:34 PM
