Results 1 to 6 of 6
Thread: 4AFE to 4AGE differences.
    What are the main differences between a 4AFE and a 4AGE?
    Do they just use a different head, possibly different rods? Or is a 4AFE completely differnt to a 4AGE?
    Any help is much apreciated. Thanks, Matt.
    Elite rthy's Avatar
    Leo
    Tulla
    many differences, I have written a bit on here, this is your best bet:
    As a summary the F stands narrow valve angle in the head, also don't believe people when they say that wide valve angle is for more power, its bullshit
    Thanks Sam, a good read.
    I am still a little confused, it may have been in there and I may have missed it. But is it possible for a 4AGE head to be put onto a 4AFE block.
    Basically what I'm trying to establish is weather or not I could buy a 4AFE engine, then also buy a bigport 4AGE head to use on it (and also obviously an ECU, loom, etc. I already have bigport RWD manifolds, etc.) Is that possible, and if it is, will it produce approximatly the same power as a 4AGE?
    Maybe I should read that link again once I have slept.
    Thanks again.
    Elite rthy's Avatar
    Leo
    Tulla
    the pistons could be different however it could probably still work. The valves should still clear the pistons but they no longer will when a belt snapped. All this is an educted guess though.
    However the 4afe is its stock form is a low rpm engine and I believe the crank is a cast crank instead of the 4age forged crank. Now I am not saying it wont hold up but I don't know for sure.
    So all in all I don't recommend it seeing how cheap they go for sometimes
    Leigh
    Penshurst
    <div class='quotetop'>QUOTE (Sam_Q @ Aug 21 2008, 09:29 PM) </div>
    I'm thinking the dizzy is in a bad spot aswell you will have to butcher the fire wall to fit her in (at least that's what it looked like you would need to do when I looked at getting one for my car a while back)
    Elite rthy's Avatar
    Leo
    Tulla
    well I didnt mention that because it wasnt mentioned if it was for a fwd or rwd install.
  1. can i use any 4age manifold stuff on 4afe??
    By bradae86 in forum Technical - Questions
    Last Post: 23rd July 2017, 07:15 AM
  2. 4AGE Dizzy Differences
    By randomskate in forum Technical - Questions
    Last Post: 25th June 2011, 03:49 PM
  3. difference between a 4afe and 4age
    By gumbie in forum Technical - Questions
    Last Post: 12th February 2009, 12:16 AM
  4. 4AFE -> 4AGE
    By flamingheads in forum Technical - Questions
    Last Post: 13th March 2007, 08:30 AM
  5. 4AGE engine differences
    By danga005 in forum General Topics (No Technical Questions)
    Last Post: 25th August 2006, 01:52 PM
