Page 2 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 11 to 20 of 239
Thread: The Wheel Fitment Thread
  1. #11
    Senior Member Beck's Avatar
    Andrew
    I coulda swore this was originally posted in Technical - Questions.
    /shrug
    Great thread, anyway. It's helpful for me (trying to decide on size/offsets for new rims atm). So thanks guys, and keep 'em coming.
  2. #12
    Senior Member klusio's Avatar
    Kieran
    Standard KE70 everything with cut springs/on bump stops
    15x8 -4 superlites 195/50/15 (edit: front tyres are a semi slick)
  3. #13
    Elite rthy's Avatar
    Leo
    Tulla
    SSR Longchamps XR4's 15x7 +11
    195/50r15
    AJPS 8kg front and 6kg rear
    4x4 15x7 0(or neg) Sunraisa wheels with drilled center to 4x114.3
    195/50r15
    Lovell superlows ae86
    Toyota Supra MA61 14x7+8et
    185/60r14
  4. #14
    Veteran Konakid's Avatar
    Henry
    Eastern
    Here's a few.
    Fr:
    - XT130 LCA
    - 14x7 +1 (+8 with 7mm spacer)
    - -1.5 camber
    - rolled guard, liners removed, no rub
    - 185/60
    Rr:
    - 14x7 +6 (+11 with 5mm spacer)
    - bashed guard no rub
    - 185/60
    6 and 4.5kg springs.
    Fr:
    - 14x8 +-0 with 185/60 tyre
    - xt130 LCA
    - -2.5 camber
    - flared guard following original guard curve.
    - rubs often at the top of the guard
    - 8kg spring
    Rr:
    - 14x8 -22 (-12 with 10mm spacer) 185/60 tyre
    - 200mm 6 kg spring
    - ke front guard flared and welded on
    - trimmed at the top so as not to stick out too far, ~ 20mm less width.
    - rubs when thrashing
    Fr:
    - 14x8 -6, 195/60 tyre
    - ~ -2 camber
    - stock guard
    Rr:
    - 14x8.5 -13, 195/60 tyre
    - stock guard
    FR, RR:
    - 15x8.5 -6
    - 195/50 tyres
    - ~-2 camber front.
    Easy fitment for a standard guard flare (lips pulled out)
    Panda car is stock guard fitment, still works, just more poke.
    FR, RR:
    - 14x7.5 -3.5 (yes it is 3.5 mm)
    - 185/60 tyres
    - ~-2.5 camber front.
    - stock guards, wouldn't rub with a roll, flush stock guard fit.
    FR, RR:
    - 15x8 +-0
    -195/50
    - front guard roll + slight pull
    - rear rolled guard
    FR, RR:
    - 15x8 +-0
    - 195/50
    - ~-1.5 camber
    Perfect stock guard E7 fit, flush with guard line pretty much if not a bit out.
  5. #15
    Senior Member n00bvak's Avatar
    Novak
    SOR
    things that do not fit, for now
    s13 front end conversion(s13 lca, tein camber tops, ca hubs) max camber
    s13 d2 coilies (no flame please, got them cheep-cheep 2nd hand)
    Sportmax 002 15x8 -+0 offset
    205x55r15
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
  6. #16
    Henry
    Eastern
    Rules edited.
    The rules, read them.
    Ta
  7. #17
    breno
    13x7 - 30
    165/55R13
    86 struts, sigmas, rca's, -4.5 camber front.
    Guards just hit out with a rubber mallet and pulled with plyers on the rear.
  8. #18
    Senior Member superbmobile's Avatar
    Justin
    Happy Valley
    Front
    14x8-10
    185/60r14
    flared guards, 86 struts, corona arms, rca.
    Rear 14x8.5-4
    185/60/r14
    rolled guards
  9. #19
    Ken
    Spearwood
    Rears - 14x7 +1 offset with 25mm spacers. Rolled guard. 185/60/14
    Front - 14x7 +1 offset with +25mm spacers. Flared guard. 185/60/14
  10. #20
    Senior Member Stain's Avatar
    Derek
    Far North
    There is no way that's -2.5 camber. It'd have to be around -5!
    I agree that there should be no posting of cars that arent your own.
    How can you be sure of the specs of all those cars Konakid?
    Could lead to an expensive lesson for someone who based their rim choice on one of those.
  1. Wheel fitment thread- post your will this fit questions in here
    By Sam-Q in forum Technical - Rims & Tyres
    Last Post: 10th December 2018, 09:31 PM
  2. Biggest dish, stretch and mint fitment thread!
    By johl in forum Technical - Rims & Tyres
    Last Post: 5th May 2014, 10:33 PM
  3. 15x8 +20 borbet wheel question! dnt no much about wheel fitment...
    Last Post: 13th April 2011, 11:43 AM
  4. Wheel Fitment.
    By corknose in forum Technical - Rims & Tyres
    Last Post: 4th September 2009, 09:22 PM
  5. Wheel Fitment
    By Zach in forum Technical - Rims & Tyres
    Last Post: 30th December 2008, 11:44 PM
