Page 3 of 24 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 ... LastLast
Results 21 to 30 of 239
Thread: The Wheel Fitment Thread
  1. #21
    Senior Member Stain's Avatar
    Derek
    Far North
    16x7.5 +12
    205/45r16
    6kg 220mm Spring
    Cusco Strut Tops
    30mm RCA
    Corona (10mm longer) LCA
    Power Steering Arms
    -3 Camber
    Sigma (30mm longer) LCA
    -6 Camber
    Both fit without scrubbing. But as soon as I lowered the camber back to -3 with the Sigma arms it touched. Flaring the guard fixed that problem.
    The fronts still hit the little brake line bracket in the wheel arch on full lock, but only just. So I'm not worried.
    16x8.5 +17
    205/45r16
    4.5kg 260mm Spring
    T18 T-Series w/drums
    No dramas
  2. #22
    Veteran Robo86's Avatar
    Rob
    Wheels: 14x8 -15 . 185/60/14
    Suspension: XT130 LCA, Coilovers etc, Normal RCA
    Camber: -3
    Guard Work: Flared Guards
    Wheels: 14x8.5 -22 . 195/60/14
    Guard Work: Custom Compact guards (front on rear)
    Suspension: TRD coilovers
    Diff: T Series
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  3. #23
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Wheels: 15x8 -4 Performance Superlites (GTR), Bridgestone RE-001 195/50R15
    Suspension: Corona LCA's, AJPS coil-overs, 33mm RCA's
    Camber: Just over 1 Degree each side
    Guards: Fully flared by Dimitri
    Rear:
    Wheels: 15x8 -4 Performance Superlites (GTR), Toyo Teo Plus 195/50R15
    Suspension: TRD Blue 8-way Adjust, 210-215mm AJPS 6kg springs
    Diff: T series.
    Guards: Rolled the inner lip with a 2" pipe just to tuck the lip
  4. #24
    Veteran slydar's Avatar
    Dimitri
    should mention, robos front guards are actually trimmed back to the 1st crease, so they are actually the same width as stock (with a rolled inner lip) guards, but higher.
    you wouldnt be able to run that combo with stock guards though, even if you car wasnt as low, because of the way the lip would interfere with the tyre.
    his rears are about +20mm, but about 20mm higher too.
  5. #25
    Senior Member koulouris#03's Avatar
    Nsw
    EarlwoodNsw
    Au
    hi guys.
    i have an ae86 with rx7 caliper upgrade.
    what size, offset, and dimension off wheel would work on this particular setup???
  6. #26
    Senior Member doony's Avatar
    Dan
    moar!
    Or driving in a wolf pack.
  7. #27
    Aaron
    In the Mountains
    wheels: 16x8 +13 works
    tyres: 205/50 (i think)
    guard work: trimmed plastic inners
    susy: aprox -1 camber, 10kg springs, stock lca, no rca or camber tops(no scrub except on lock on innder guard)
    wheels: 14x7 +11? with 25mm spacers
    tyres: 175/65
    guard work: mild hand flared
    susy: 4.5kg TRD springs 210mm free hight
    wheels: 13x7 -5 superlights
    tyres: 185/65
  8. #28
    Just Half Steppin
    15x8 -18
    195/50/15
    coilovers, 40mm rca, lca +30mm, camber tops set to full positive -3.5 camber, hand flared guard
  9. #29
    Veteran Konakid's Avatar
    Henry
    Eastern
    That looks like -2.5 or so camber.
    Have you had it aligned yet or are you guessing?
  10. #30
    Just Half Steppin
    its 3.5
  1. Wheel fitment thread- post your will this fit questions in here
    By Sam-Q in forum Technical - Rims & Tyres
    Last Post: 10th December 2018, 09:31 PM
  2. Biggest dish, stretch and mint fitment thread!
    By johl in forum Technical - Rims & Tyres
    Last Post: 5th May 2014, 10:33 PM
  3. 15x8 +20 borbet wheel question! dnt no much about wheel fitment...
    Last Post: 13th April 2011, 11:43 AM
  4. Wheel Fitment.
    By corknose in forum Technical - Rims & Tyres
    Last Post: 4th September 2009, 09:22 PM
  5. Wheel Fitment
    By Zach in forum Technical - Rims & Tyres
    Last Post: 30th December 2008, 11:44 PM
