15x8.5J -21 195/50R15 Origin FRP Fenders (Lipped), Coil-Overs, Camber Tops -2.25¤, Cusco RCA and Castor +4¤.
15x9J -2 195/50R15 Rolled Guards, Coil-Overs
But when FD brakes fitted to front required 12mm spacer to clear caliper. so moved 15x9 -2 to front resulting in same outer rim position with spacer.
The 15x8.5 -21 on rear now scrub over larger bumps so rear guards will require some more modification for smooth running. Current stance:
