dreaming
they are fucked those ones, such a crap set up
the ones they supply break
the ones you can get made cost $$
I tried everything with mine, ended up taking them to the local engineer and then scrapped them
shame....
Hey i am chaseing the special tool to undo the bolts holding on my bolt on spacers. as seen in this pic
if anyone in SA has one, i would like to use, borrow or buy it
would be sick if i could get the bolts ons off before this weekend as i cant drive without struts and i cant put the struts in with the spacers on.
cheers!
contact 0403 279 862 -ALex
Formerly known as grape_moosha
dreaming
shame....
gay, yeah today i swapped my hubs off my other struts so il just hold onto these hubs i guess, get them off one day
i would suggest trying different nuts, but looking at the pic it appears to have a different taper to the standard 60deg...
how do ppl make products like this?? spewin
that brand has since update their nuts
try a set of needle nose pliers and a big set of multigrips
make your own? some flat bar and some hi tensile bolts.
Pin punch + hammer + vice + patients = loose nuts, then as someone said up top, crirclip pliers and away you go.it sounds like a very shiz setup. Goodluck! If you want, you could give me a hub and I could see if I coul make something at work? Cheers
