Shotgun crank. I'll shoot you a PM.
From AE92 SX Smallport:
set of timing belt covers $30
fwd exhaust manifold $5
212mm clutch $50
injectors $30
knock sensor $30
FWD 4AGE engine mount set – new lh & rh, filled fr $20
AE82 twincam PS setup $25
AE82 twincam radiator $25
AE82 twincam fr swaybar $15
AE82 twincam airbox & piping $25
AE82 twincam front strut casings $25
AE82 twincam front & rear std rubber strut tops $25
AE82 twincam front strut braces $25
AE82 silver bonnet & front guards $25 ea
AE92 SX C52 gearbox $200
MX83 2.5" cat back exhaust $50
MX73 cat back exhaust $50
AE82 thermostat housing $20
2x random honda front seats with rails to suit AE82 $200
rt142 radiator $25
Located in Hobart, Tasmania
You can pick up or I can post at your expense
Can u please pm me ur number.
Im local, can pickup, interested in a few bits.
Yes! Finally a crank for Deeken!
does small port dizzy, alto and starter fit bigport ? if so i want
also harmonic balancer if you have one and it fit's big port and is the same fwd for rwd
The starter will fit no worries, dissy will fit the head, but not sure on the electronics side of it, i.e. if it'll work with a bigport loom & ecu, etc.
alternator will prob bolt up, but not sure if pulley will align with rwd pulleys... maybe someone else can help out here...
ok well you can say they sold if they will fit.... will do some research tonight and pm you buddy.
fwd crank pulleys aren't interchangeable with rwd setups from memory the ae86 rwd pulley sits out a couple of extra mm.
Ill be in Hobart all weekend mate, ill pm you my number. Interested in a couple of items.
Still heaps of good gear here guys.
