Results 1 to 9 of 9
Thread: RA65 Calipers Needed
    Veteran Konakid's Avatar
    Henry
    Eastern
    Default RA65 Calipers Needed
    Hey all im after a pair of RA65 Celica Front calipers in decent condition, have cash waiting, can pickup. Or if anyone sees some at U Pull It or similar let me know, cheers!
    Site Supporter Javal's Avatar
    Josho
    For your information, these are also the same as RA60 and SA63 calipers.
    Henry
    Eastern
    Thought so, use the vented rotor? I cbf looking therough my info to check.
    Josho
    They all use the same rotor. DBA146, 258mm x 20mm. You have no info.
    Veteran AJPS's Avatar
    Lonsdale
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Same as MA61? Because i have a set of them.
    Jan 2010
    Luke
    Woodside
    I have a pair here if needed.ra65
    Josho
    They take the same rotor, however I am unsure if the bolt spacing on the caliper is the same, so proceed with caution.
    Henry
    Eastern
    Caution noted. Calipers sauced. Big ups KE11!
  1. FC RX7 BRAKE CALIPERS needed ASAP Sydney/Newcastle
    By ae86 drifter in forum Cars or Parts Wanted
    Last Post: 14th August 2012, 08:45 PM
  2. Lock stops really needed? RA65
    By Seventy in forum Technical - Questions
    Last Post: 12th May 2012, 09:31 PM
  3. Jarrad's RA65
    By Jarrad86 in forum Other Toyotas
    Last Post: 16th October 2009, 12:09 AM
  4. difference between adm calipers and jdm calipers
    By benzo in forum Technical - Questions
    Last Post: 26th August 2009, 07:02 PM
  5. Cold start injector pipe needed, 4age needed inSA
    By ian6375 in forum Cars or Parts Wanted
    Last Post: 2nd June 2009, 05:35 PM
