did T3 offer any suggestions?
hEY GUYS ,
Have a bit of a issue. have just fitted t3 tie rod ends and steering arms to my ke70 and do not have enough adjustment.
now i kow a good upgrade is ra60 rack ends/tubes but in this case with the t3 tie rod tube the rack end must have a thread on it for the tie rod to screw onto.
so im on the hunt for a extended rack end thats the same as a ke70 one but longer.......... i dont know where to start looking or if there is another way.
cant use the stock tie rod due to the hole for t3 steering arm been 3-4 mm larger
Help!!!
nichy
THEY SHOULD FIT LOL
may be my sigma lca's though....
I would have thought the t3 tie rod ends would have enough adjustment for the sigma lca's?
to be honest so did i been t3 and all.... but hey in saying that i didn;t ask.
What about the ajps rack ends?
are they a thread or a tube ? has to look the same as a ke 70 one does
How much too short are they? you could probably get away with just a lock spacer.
rack ends
lock spacer
