Results 1 to 10 of 20
Thread: Broken wheel nut (Need tips on removal)
    Member GOT-20V's Avatar
    Simon
    Central Coast
    Default Broken wheel nut (Need tips on removal)
    Hi,
    Bought a car the other week that has cheap wheels and nuts and one of them is broken (refer to picture)
    How would you remove it?
    I was just going to drill small holes in it since it's light alloy and chisel it till it breaks, or is there a better way..
    Senior Member Stain's Avatar
    Derek
    Far North
    You risk damaging the wheel if you drill the nut.
    I'd try getting a old socket and smashing it onto whats left of the nut then taking it off with a breaker bar.
    If that fails prob better to just drill the stud (along with the nuts thread) out with a good quality metal bit.
    You'll have to get a new stud after tho obviously.
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Do this. Will work.
    Remember to use a low speed an lots of cutting oil/grease/material on the drillbit.
    Simon
    Central Coast
    Okay thanks guys i will give that a go by drilling it well lubricated and then replace the stud afterwards.
    Jul 2009
    Vic
    Try using a big socket first, you might get lucky.
    Senior Member Hachi_Tom's Avatar
    Mar 2010
    Tom
    Ashmore
    or punch it off
    with a punch.
    counterclockwise
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    falconpunch?
    Veteran Bustin_86's Avatar
    Justin
    North-West Coast
    I have jad a similar problem. I welded a bar onto the nut then gpt it off, of all else fails take it to a mechanic lol
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    Tighten the other 3 wheel nuts more then chisel that one counter clockwise
    Aug 2010
    Geoff
    mt dandenong
    chuck norris
  1. wheel nut size?
    By ke.slider in forum General Topics (No Technical Questions)
    Last Post: 8th July 2010, 01:20 PM
  2. where to buy a stake nut?
    By tauhu86 in forum Perth & WA Events and Discussion
    Last Post: 3rd June 2010, 09:56 PM
  3. Ouch; broken wheel content
    By Chairs with flares in forum Offtopic Discussions
    Last Post: 5th April 2009, 11:32 PM
  4. Steering wheel removal.
    By Mickey H in forum Technical - Questions
    Last Post: 16th January 2009, 01:24 PM
  5. wheel paint removal
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 4th August 2007, 09:10 PM
