Hey yes thanks that's just the ones I like, most of them are from newzealand performance car magazine the best nz car mag. Comes with a poster each issue. Others are from aussie mags.
I've had a squeeling coming from my gearbox engine area. Got much worse last week sounded like grinding. Was only when the clutch pedal was engaged so thought it was release bearing.
Pulled the gearbox out this week after work and the bearing was stuffed, when shaken it would rattle.
Really hate working on my car when I need to fix things, modifying is fun, fixing is not.
Anyone have pictures of where vacuum lines should be on a 20v rwd conversion? Where is the brake booster vacuum supposed to run to? Car still won't idle any suggestions? It's timed correctly has fuel and spark. Drives perfect and goes hard pulling throughout the revs just won't idle.
Hi guys broke the plug part of the reverse light switch last week. Considering its over 25 years old it was fairly brittle. <br />
Did some research online and found trs007 but it wasn't right. Was incorrect thread size too large and it had a integrated ball unlike the one from my box. (lol) <br />
Any ideas of what the part number would be in the tridon brand as I work at Repco, other wise a genuine Toyota part?
Hey,
That white trueno notch at ruapuna a couple of pages ago i build it all. Have you got any more info on it now? Know the guys name or seen it any where?
If you need any help with that 20v let me know.
Cheer Cody
Hey man not sure what the guys name is but he's using it in drift south as far as I'm aware, as well as doing circuit racing aswell. Very nice car quite fast I out braked it in most corners though.
Its got standard s13 brakes and mintex pads. Hilux Drums in rear. Not much compared to wilwoods
I didn't bother too much as it wasn't built as a circuit racer. Bolt on gtst 4 pots though which was planning on.
Its only running standard blacktop. W55 hilux diff. terrible 4.3 ratio too. should be alot fast with 4.8 or higher
Yours in really nice too. Always looked out for it at repco
Do u have another AE? Why did u get rid of it?
More of a builder than a racer and change of plans
