Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Toms Turbo A (ma70) Wangan lover <3
    Dec 2009
    Guy
    qld
    toowoomba
    Default Toms Turbo A (ma70) Wangan lover <3
    Turbo A
    1988 ma71 Supra "turbo a" variant.
    Purchased this a few years back and it has been on and off jackstands ever since. Im constantly upgrading changing and breaking things. So far ive rebuilt the engine twice for bearing failures caused by oil starvation from silly issues that have been corrected and also have rebuilt the r154 due to 1st gear thrust washer failure and subsequent chewing of the gearset.
    mods list!
    Engine
    7m-gteu
    Nitrided 6m crank
    Balanced rotating assembly
    Eagle rods
    9:1 CR Arias forged pistons (20thou or .5mm oversize)
    Running standard camshafts and standard cam wheels.
    BC 1mm oversize stainless valves with 3 angle grind
    BC valve springs (thick ass single springs)
    BC titanium retainers
    Port matched manifolds and a slight port polish with good surfacing
    Cometic MLS head gasket 1.3mm (total cr is about 9.2:1 ish)
    ARP head studs, main studs, and rod bolts
    HKS SUPER POWER 3 layer foam air filter
    fabricated steam pipe exhaust manifold with 6 into 1 merge collector
    Garrett gt3582r turbo with .82ar rear housing and internal wastegate with 8psi actuator
    all braided ss lines for turbo oil and water
    fabricated stainless 3 inch dump pipe into 3inch stainless exhaust with high flow cat and some random cannon type muffler
    Turbosmart 1.5inch plumb back bov
    HKS fuel cut defender to prevent boost cut
    Apexi AVC-R boost controller, currently running 1.0BAR or 15psi
    hi flow thermostat
    koyo racing radiator
    mishimoto twin thermo fans with shroud
    relocated coolant reservoir to back passenger corner of engine bay.
    home made 3'' stainless intercooer pipes. Oh and massive 4" intake pipe sexxaayy
    600x300x80 HDi fmic with 3" inlet and outlet
    Ron R mid runner ffim
    Sethron 90mm Throttle body retaining standard tps using eccentric throttle pulley
    heat shielded intake manifold gasket
    deleted A/C
    wesbeech altenator bracket dropping alt down to where ac used to be
    oil system running via permacool filter relocator -> oil filter -> permacool oil thermostat -> big ass 19row earls oil cooler -> Moroso Accusump with on off switch controlled in car -> engine. All through -10 aeroequip push lock hose and fittings.
    running castrol edge 0w-40 oil.
    bearing clearances set to .0025inches
    Fuel System
    255lph intank walbro
    pulp
    injector duty still good
    Driveline
    Lightweight flywheel (Supposedly OS gilken)
    Exeddy semi cushion brass button clutch.
    Short shifter (unknown brand supposedly cusco)
    Marlin crawler shifter bushings
    Redline mt90 gear oil in standard r154 transmission (freshly recoed)
    TRD LSD using reccomended weight redline oil
    Sussy
    whiteline front swaybar
    cusco front strut brace and ebay rear strut brace
    koni yellow shocks and selby springs courtesy of IJ
    Brakes
    ARZ 6 piston 13'' front brake kit (willwood calipers rotors and pads)
    ARZ 4 piston 12.9'' rear brake kit with handbrake (willwood calipers rotors and pads)
    braided lines
    dot5 fluid
    Interior
    Momo race 300mm wheel
    Cusco handbreak lever
    recaro seats from jza70 so huggy
    greddy electronic boost, oilpressure and water temp guages
    autometer electric oil temp, af ratio (displayed in a red yellow green arch of lights rather than a number) and voltage guages
    greddy turbo timer
    crazy awesome alarm system
    some stereo crap who cares
    battery relocated to boot!
    Rolling on 17inch work equip wheels with dunlop sport sp 200 rubber 255 on rear and 235 on front. mmmm grippy, and expensive
    The hardcore engineering stuff like block and head surfacing, honing bores, setting clearances, line honing etc taken care of by my engineer Craig at express engine reconditioners in Toowoomba and fabrication of exhaust manifold and dump pipe done by Shannon at MTQ engine systems also in Toowoomba. Shannon and Craig are both awesome at what they do and have answered (endured) all of my questioning and nagging like champions. All the assembly and research was done by yours truly along with A lot of help and technical trickery learned from my mate beau who works as a mechanic in town who also toiled away long hours in the garage with me.. thanks beau also beau is a badass welder haha
    I think thats the lot
    for now
    phase four will involve aftermarket ecu (undecided as to which)
    and a massive fuel system overhaul (surge tank, bosh 044, 1000cc injectors, afpr and all new fuel lines)
    i will build fuel system in mind for even more expansion down the track to accommodate a 2nd Bosch 044 and twin entry rail for e85 tuning!
    MOAR PICTURES
    this is of the work im doing to the car currently. invoving the big brakes and forward facing manifold conversion.
    The engine bay piccies arent quite up to date but ill be sure to post more pictures soon.
    Feel free to comment and ask questions in thread etcetc
    So just keep in mind the next time ur at a drift meet and someone asks u why ur not out there ripping it up with the other sikunts, don't say "I'm waiting for my coilovers to arrive" or "my gf wont let me drive sideways", u say "I flatspotted my tyres on my HUUUGE 120km/hr entry and if u missed that then ur TOO LATE BIATCH"
    Member beauboostr's Avatar
    May 2011
    Beau
    Toowoomba
    WIN!!!
    full time mechanic... part time toyota tech lol
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    this thing is awesome!!! good to see someone persisting with a 7m
    MY JZX83 (clicky)
    Dec 2009
    Guy
    qld
    toowoomba
    haha thanks. I quite like the 7m i think its a fine engine. It seems to have developed a bad reputation.
    Brendan
    NORTHSIDE YO
    they really do have a bad rep, haha just for eating HG apprently the torque specs are too light from factory which is the reason for it
    my mate zac has 7mgte ma61 drift car and it goes fine for him jz for me though
    MY JZX83 (clicky)
    Dec 2009
    Guy
    qld
    toowoomba
    yeah that head gasket thing would be the reason. The factory specs are shit. i don’t think there is anything actually wrong with the hardware even. its just not tight enough from factory. either way, metal hg and arp studs definitely solve the issue.
    at the end of the day. u can get more out of a 2jz. but for my power goals (responsive 500rwhp) either is fine IMO
    ill give ur build threads a read when i get home from work
    Brendan
    NORTHSIDE YO
    yeah that would be it then, i was also told that the head bolts were spaced too far apart or something??? do think its a load of shit though as there is only really one spot u can put them, anwhere else and u get close to bores etc
    500hp 7m will be impressive man im making 400 with bolt ons,ecu and injectors
    MY JZX83 (clicky)
    Dec 2009
    Guy
    qld
    toowoomba
    freaking excited for matsuri. i hope to get the turbo A out there. but ill be sliding the red dragon
    Senior Member ecko's Avatar
    Jack
    Blackmans Bay
    Get onto toymods mate A70 thread there will love you
    Dec 2009
    Guy
    qld
    toowoomba
    nooo not another forum to watch hahaha... okay thanks ill check it out!
  1. 1986 Toyota Supra MA70 (7mge) NA Non-Turbo $4500 ONO
    By Sleeper in forum Cars for Sale (Toyota Only)
    Last Post: 27th June 2011, 06:02 PM
  2. 15x10 -11 meshies <3<3<3<3<3
    By stx-16 in forum Car Parts For Sale
    Last Post: 23rd January 2011, 06:48 PM
  3. [bne]gilly lip!!!<<<<<<<<<<<
    By R1CHYY in forum Car Parts For Sale
    Last Post: 29th May 2009, 11:09 AM
  4. Ma70 - white, targa, non turbo, manual
    By andro0o in forum Cars for Sale (Toyota Only)
    Last Post: 27th November 2007, 06:42 AM
