Page 4 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 31 to 40 of 121
Thread: EOI - CNC AE86 Hubs in standard size and +10mm track
  1. #31
    Veteran Kid Karola's Avatar
    Karl
    S.A.
    Austria
    in case you missed it...
    K1045 is a Steel Alloy (Carbon, Manganese) Typical uses include gears, shafts, axles, bolts, studs, and machine parts.
    Just to reiterate: aluminum and alloy are NOT the same thing. There are Aluminum alloys, Steel alloys and many other types of alloys.
    There are various grades of so called "Air-Craft" alloy commonly used in aero-space industry, with different properties depending of purpose.
  2. #32
    Senior Member ae86 drifter's Avatar
    Pete
    put me down for a pair mate,10mm wider version
    ROYAL GARAGE NEWCASTLE
  3. #33
    User fantapants's Avatar
    Pat
    lol at me and others for needing the bleeding obvious pointed out .. thanks kk
    but who put sand in redspirits vag this time?
    06/07/2011
  4. #34
    Glenn ke_70's Avatar
    Clay
    Barossa!
    i think the sands in there permanently pat!
    these hubs will be perfectally fine too! any idea on a cut off date? i might be keen as i do need another pair
  5. #35
    Veteran slide86's Avatar
    Huw
    Hills
    no cut off date guys......
    im getting 4 pairs made up AFTER my own pair, which will be the test fit.....pics.....blah blah
    then they will sit at the CNC shop till they are needed ie when someone hands over $$
    we are keeping the drawings too so they can be loaded into the machine at any stage in the future if we want to do a second run
  6. #36
    Veteran slydar's Avatar
    Dimitri
    ok. so are they gonna be lighter than the stock ones?
    78's
  7. #37
    West
    Well the alloy rotor hats on the sls seem to hold together without shattering/melting or deforming.
  8. #38
    Karl
    S.A.
    Austria
    for 3rd time: alloy ≠ aluminum *&* rotor hat ≠ axle hub
    The "alloy" material used my MB, Porsche, Ferrari, etc for rotor hats on ceramic compostite brakes, and other suppliers such as AP, Alcon, Brembo, etc of high performance/motorsport brake set-ups, is not really the discusssion topic here - namely the HUB which rotates on the stub axle, to which the brake disc and wheel bolts to.
    Out of interest do you happen to know the specific alloy type/grade used by MB for rotor hats on AMG SLS? or the reasons why an alloy hat is used over a 1-piece disc? (clue part of the reason CCB are a 20-grand option is the manufacturing process, each disc is balanced to hat with weighted fastners)
    a) reduced rotating mass and unsprung weight.
    b) less heat transfer-soak to hub and bearings.
    c) nature of carbon/ceramic compound not suitable for mounting assembly itself.
    d) all of above.
    e) other?
  9. #39
    Dimitri
    yes, got it this time Karl
    i can understand why you would want these hubs if you wanted the +10 track/brake clearance.
    but i only want them if theyre significantly lighter. i dont know the properties of K45 so..?
    78's
  10. #40
    Clay
    Barossa!
    1045 is a medium tensile steel. not quite as good as 4140 but alittle better than normal mild steel.
    it's not really an amazingly awesome grade of steel.
    im not sure on the weight though, but i can't see it being lighter than mild steel.
  1. Replies: 2
    Last Post: 2nd May 2011, 08:48 PM
  2. wanted standard front struts and hubs for corolla
    By porter in forum Cars or Parts Wanted
    Last Post: 2nd April 2011, 08:17 AM
  3. standard ADM front swaybar size.
    By maxhag in forum Technical - Questions
    Last Post: 8th September 2010, 02:22 AM
  4. Need standard ke front struts, lcas, hubs
    By Brenton 86 in forum Brisbane & QLD Events and Discussion
    Last Post: 21st July 2009, 02:50 PM
