Page 7 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 61 to 70 of 121
Thread: EOI - CNC AE86 Hubs in standard size and +10mm track
  1. #61
    Member Y-B-NRVS's Avatar
    May 2010
    Rodney
    nsw
    liverpool
    yeah man come on what tha frige is goin on?
  2. #62
    Veteran slide86's Avatar
    Huw
    Hills
    PM's have been sent.
    Sorry for the delays.....but working in a QLD coal mine doesnt make things like this super easy.
    Still more spots available for interested parties.
  3. #63
    Senior Member ae86 drifter's Avatar
    Pete
    deposit made
    ROYAL GARAGE NEWCASTLE
  4. #64
    Pete
    quick question do the studs recess into the hub? otherwise u loose 20mm of stud
  5. #65
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Silly question but what's the advantage over OEM?
  6. #66
    Veteran AJPS's Avatar
    Lonsdale
    moves rotor away from lca with some brake conversions
    10mm extra track
  7. #67
    Senior Member Stain's Avatar
    Derek
    Far North
    I'm confused.. If it moves the rotor away from the lca... Wouldn't you need to modify your caliper bracket to move it out aswell?
    I thought these left the rotor in the same place and just added 10mm of thickness on the outer side to give extra track...
  8. #68
    Lonsdale
    sorry i was thinking of something else
    it moves the WHEEL 10mm from the caliper
    my mistake
  9. #69
    Huw
    Hills
    yeah, as per the drawing on the first page, it adds 10mm to the OUTER surface to push the wheel out further.
    in other news, im really impressed with the quick response of the deposits!!
    The shop has been given the go ahead, ill keep people informed of progress.
  10. #70
    Pete
    wats going on with these mate
  1. Replies: 2
    Last Post: 2nd May 2011, 08:48 PM
  2. wanted standard front struts and hubs for corolla
    By porter in forum Cars or Parts Wanted
    Last Post: 2nd April 2011, 08:17 AM
  3. standard ADM front swaybar size.
    By maxhag in forum Technical - Questions
    Last Post: 8th September 2010, 02:22 AM
  4. Need standard ke front struts, lcas, hubs
    By Brenton 86 in forum Brisbane & QLD Events and Discussion
    Last Post: 21st July 2009, 02:50 PM
