Results 1 to 7 of 7
Thread: *Help* Milling turbo manifold
    Timmy D
    North
    Default *Help* Milling turbo manifold
    Hey guys
    just trying to mill the face of a turbo manifold after i welded it, clamped it down the best i could and supported as much as possible. Getting really bad chatter on the left hand side (in the pic)
    any tips on how to hold it in place better? was considering welding tabs onto it somwhere
    any and all help would be great
    JJ
    Senior Member orange32's Avatar
    Zac
    Redlands
    Its pretty difficult to get a rigid setup like that. I do a lot of this stuff at work, usually only the turbo face though (head face normally gets done on a belt sander.
    Some things to try;
    - You can try and take really small cuts in that area with a freshly sharpened tool and file and emery it to make it blend into the rest of the face. As long as it is flat it shouldn't leak.
    - Chamfering all of the edges works well for keeping the tool sharp and cutting nicely as does a bit of cutting fluid (wd40 or kero are fine).
    - Using a lead hammer or similair (dead blow) and rest it underneath the flange while the tool is cutting on top. You may be able to soak up the vibrations enough to get the finish looking alright.
    - If its just that section, stop the cut before it reaches that part and add some clamps to the flange where you have already passed.
    Most of this stuff probably wont work terribly well. If you plan on doing a few of these, I'd suggest investing in a large vice and an angle plate, they can come in handy for a lot of jobs.
    Gone
    Joel
    Picton
    was going to suggest point 4 above
    Member Jaredo's Avatar
    Jared
    ACT
    Canberra
    Make a box around your current set up > fill box up with sand > add a little water to sand
    Con:
    How to clean up sand after
    tougetothedangerzone.wordpress.com
    Senior Member Casey-G's Avatar
    Casey
    surface grind it..
    Member jdm_510's Avatar
    Ryan
    Morwell
    try using a boring bar with carbide insert and fly cut it take light cuts and plenty of coolant. also make sure tool is as sort as it can be to prevent any flex if not just draw file it smooth
    Feb 2014
    Kiel
    New South Wales
    Shellharbour
    You'll probably find that middle clamp at the front isn't actually clamping down on the manifold, the bolt should be as close to the workpiece as possible.
  1. Replies: 3
    Last Post: 27th July 2011, 10:30 PM
  2. Replies: 6
    Last Post: 6th February 2011, 05:14 PM
  3. 20v turbo manifold, T25 turbo, seats, momo wheel
    By twin_cam in forum Car Parts For Sale
    Last Post: 30th May 2010, 01:21 PM
  4. turbo manifold
    By ke70astro in forum Car Parts For Sale
    Last Post: 31st July 2009, 07:29 PM
