For sale! Clearing out two workshops, need storage space back.
All deliveries can be made aus wide no problem.
All items in fantastic condition unless otherwise specified.
Lots more parts than listed, Ill keep updating this thread.
Photos available of all parts, dont waste my time dreaming though.
Photos and updates on facebook, add David Dennis, or by SMS/email.
Most items negotiable!
Located Devonport, Tasmania.
Phone Dave on 0409 631 092
HKS 3037 aka GT3076R 56 trim 4 inch anti surge compressor housing with .82 AR T3 base flange 4 bolt dump flange
$1600 this is a saving of over $400
Hks by garrett with ceramic coated housing and gate pipe on housing for perfect boost control AND cheaper, better packaged exhaust manifolds. Perfect for RB, 1j, SR, 7m, 3sgte, 4g63, 2jz, anything. Push well into the 300rwkw barrier with insane induction noise. Highly reccomended by leading tuners such as Trent @ Status/Checkered Tuning and Donny @ Streetforced
0409 631 092, or David Dennis on facebook
WHEELS
Skid rims for sale, 5 stud suit ford Silvia Mercedes etc, jap Ssr hasemi, 16x8, $200 pair.
14x7-9 rewinds/superlights $400, 15x8-ish challengers $450. 4x114.3 No Tyres. Wheels in excellent condition.
S13 PARTS
Boost controllers, manual T type, turbosmart brand mostly, at least 4 of them here, $20 each
S13 Square/J's Headlights $300
Passenger indicator/park light $30
S13 tail lights, excellent condition, one set tinted other standard
S13 front lower control arms, as new $160 pair
S13 drivers side Front guard, as new $100
Reco SR20 head, less than 800km, all reciepts. Have stock cams or hks cams to suit. $250
Perfect s13 fuse box cover $20
SR20DET PARTS
S13 SR20 Redtop Power FC, two of, one with hand controller. $700 without, $900 with, the one with hand controller is basically brand new in box with all manuals etc.
S13 SR20 engine loom, perfect condition $200
SR Gearbox, perfect condition $550
SR20 Extreme Drift Clutch + Lightweight Flywheel, good condition, Retail 1600+ for the kit, sell for $800
SR20DET cast iron factory turbo manifold, as new low km, 4 of, $50 each
SR20DET .2mm oversize factory pistons, brand new in boxes, retail over 300 each, sell the set cheap for $500 delivered
LS1 S13 CONVERSION
Bolt in crossmembers, DAFT INNOVATIONS mounts and such for LS1 into S13. My own design Earls power steering line kit, earls/canton racing oil cooler setup size of a4 page, starter motor which clears the steering shaft etc etc. Not cheap, all parts brand new in boxes except for crossmember and mounts. 450 mount kit and custom crossmember. 200 power steering lines, 1000 oil cooler, 350 starter motor, also have fuel system lines and filters for 250, all earls lightweight stuff. Will not seperate.
RB26 PARTS
R34 GTR Tomei Type A Poncams, 260in 252ex 9.15mm lift, brand new, justjap want 1400, sell for $700 delivered
RB26 Custom Made JE pistons, 86mm bore, made specifically to use factory rings, world reknowned for being the best rings available. Brand new in packaging, comes with pins and spiral locks and a full set of factory rings, most places selling for 1600+ bargain at $1100 delivered
R34 GTR N1 block, split bore, needs one sleeve then better than new! $1000 plus post
New wastegate actuators, details unknown but would be R34 or nismo items $25 each
R34 GTR PARTS
Nismo suspension bushes, purchased to suit R34, will fit other skylines/silvias. All new in box, find the part number u want and call me and ill tell you if i have it. Will sell half price of the best price u can find on the net.
R34 GTR N1 Vspec2 front grill for bumper, brand new, not sure on value, must be cheap at $100 delivered
R34 GTR N1 side skirts, 2 peices per side, need paint but other wise good condition $300 plus post
R34 GTR N1 Carbon Fibre Undertray, Brand new never fitted, Cost over $9000, selling cheap, call for details.
R34 GTR 18" Wheel center caps, immaculate condition, set of 4, $100 delivered
R34 GTR Front Windows or Windscreens, One brand new, one used but as new, Cheap as chips, call for details, can send worldwide.
EVO 7 PARTS
Evo 7 Yellow Top Feed 560cc injectors $220 delivered
Evo 7 Factory shocks/struts/springs, as new, never done any work, refresh your old ones. $50 plus post
Evo 7 Ralliart Air Filter, new in box, $50 delivered
Evo 7 Timing Belt, new in box, $50 delivered
Evo 7 Synrorings/hubs $CALL
RANDOM PARTS
S14 series 2 front bar, looks good, brand new in white gel coat. Must sell ASAP! Make a decent offer
S14 Ganador Mirrors $100
Luisi 300mm and Personal 350mm wheel $100 each
1jz twin turbo setup, complete good condition $150
1jz stock clutch setup, complete good condition $150
4age ae86 radiator, excellent condition, looks new $100
4age rwd ae86 212mm flywheel and heavy duty PBR clutch, excellent condition never slipped on me, $200
RB20 fans, engine covers, power steering, alternators, crank sensors etc etc
CA18 Bellhousing - Free if picked up
E20 Van Bellhousing, good for L Series engines
Edelbrock 350 Chev Rocker Covers, Brand new in packaging, shiny shiny for your street machine, Beat any advertised price by 25%
Mallory 350 Chev Performance Ignition System, Unilite Breakerless, Part number 3748201, Brand new in box with a set of new blue top gun leads, will beat any advertised price by 25%
Powerbond 283ci to 350 chev small block v8 7" Street Crankshaft Dampener or Harmonic Balancer, Brand new in box, part number PB2221-ST, will beat any advertised price by 25%
Turbosmart Progate 45mm, as new with V band clamps
S14 SR20DET factory radiator $25
LS1 A/C compressor $20
VG30 Block, girdle and sump $50
CARS FOR SALE
1972 Triumph 2.5L PI (injected) complete car suit restoration, has engine and all running gear, two spare heads, two manual gearboxes, with one overdrive, all chrome trims immaculate, brand new door and Windscreen rubbers, shell is as it good as it gets, next to no rust, no damage. $800 or offers, keen to move, need shed space.
Widebody Sil80 rolling shell, widebody front and rear, fibreglass bonnet, bodykit, coilovers, all adjustable arms, can come with cobra seats or no seats, just add paint, engine+accessorys and gearbox. $3500 with seats, 3000 without.
